abriviations, acronyms all you need to know
Old Aug 13, 2006 | 01:33 AM
slow420a's Avatar
Default abriviations, acronyms all you need to know
3KGT 3000GT
3/S 3000gt/stealth
A/F Air Fuel (ratio)
A/T Automatic Transmission
ABS Antilock Braking System
AFC Air Fuel Convertor
AT Automatic Transmission
BDC Bottom Dead Center
BHP Brake HorsePower
BOV Blow Off Valve
CAI Cold Air Intake
CARB California Air Resource Board
CCA Cold Cranking Amps
CEL Check Engine Light
CKP Crankshaft Position Sensor
CL Closed Loop
CMP Camshaft Position Sensor
CPS Crankshaft Position Sensor (CKP)
CR Compression Ratio
DAC Digital Analog Convertor
DIS Direct Ignition System
DSP Digital Signal Processor
DOHC Dual OverHead Cam
DSM Diamond Star Motors (Mitsubishi/dodge/Chrysler)
ECU Engine Control Unit
ECT Engine Coolant Temperature
EGR Exhaust Gas Recirculation
EGT Exhaust Gas Temperature
EPROM Erasable Programmable Read-Only Memory
EEPROM Electrically Erasable PROM
EVAP EVAPorative emission control system
FCD Fuel Cut Defencer
FMIC Front Mount InterCooler
FPR Fuel Pressure Regulator
FTW For the win
GS grand sport
GST grand sport turbo
GSX grand spot all wheel drive
HO2S Heated O2 Sensor
HP Horsepower
HVAC Heating, Venting, Air Conditioning
I/E/H Intake / Exhaust / Header
IAC Idle Air Control (ISC)
IAT Intake Air Temperature
IC InterCooler
IMO in my opinion
ISC Idle Speed Control (IAC)
ITC Ignition Timing Convertor
LIC Lower Intercooler Pipe
LSD limited slip differential
LOL laughing out loud
LMAO laughing my *** off
LMFAO laughing my f***ing *** off
M/T Manual Transmission
MAF Mass Air Flow
MAP Manifold Absolute Pressure
MAT Manifold Air Temperature
MBC Manual Boost Controller
MFI Multiport Fuel Injection (MPI)
MT Manual Transmission
MPI MultiPort fuel Injection (MFI)
N2O Nitrous Oxide
NOS (Holley brand) Nitrous Oxide Systems
NA naturaly aspirated (N/T = non-turbo)
O2S Oxygen Sensor
OBDI On Board Diagnostics I (95 cars)
OBDII On Board Diagnostics II (96+ cars)
OEM Original Equipment Manufacturer
OL Open Loop
PCM Powertrain Control Module
PSI Pounds per Square Inch
Rice deacals on cars, big wings, anything that was in f&f, 2f2f, tricef&toykof... the thrid one.
RS rally sport
SAFC (Apexi) Super Air Fuel Convertor
SATAN Your local mitsu. dealer
SFI Sequential multiport Fuel Injection
Shens calling on shenanigans
SOHC single over head cam
SRS Safety Restraint System
STB Strut Tower Bar (or Brace)
TB Throttle Body/Timming belt
TCM Transmission Control Module (Automatics only)
TDC Top Dead Center
TQ Torque
TPS Throttle Position Sensor
TT Turbo Timer
UIP Upper Intercooler Pipe
UDP Under Drive Pulley
WTF What the f***
WOT Wide Open Throttle
Cyl 1, cyl 2, cyl 3, cyl 4, ect.- number give to a piston/combustion chamber dictated by the line of the fuel injectors, example: the first fuel injector that gets fed gas from the fuel line would be feeding cyl. 1, the last injector in the fuel rail that’s at the end by the shared valve feeds cyl 4.
14b, 16g, 20g, evoIII16g, big 16g, small 16g, 12g, T3, T4, t3/t4, GT28R GT35R ect... are all turbos
I would like to thank my boys: superinflamo, oldskoolturbo, theengineer, sebba, davidmitsurock, 00marage, and a big thanks to Juan Laguna.
please add to this list if you feel its important
Old Jan 7, 2007 | 02:42 AM
davidmitsusrock's Avatar
Default RE: abriviations, acronyms all you need to know
since i cant frickin copy and paste in posts anymore here is a killer list of things....
http://www.3si.org/wiki/index.php/Acronym_List
Old Sep 6, 2007 | 05:59 PM
mr.evoenvy's Avatar
you left out the all importantmivec abreviationlolthis is a mitsu forum right (Mitsubish Innovative Valve timing and Electronic Control system) just thought I'd add the best one
Old May 15, 2008 | 11:27 AM
athineltlc's Avatar
ECI electronic controled injection
Old May 22, 2008 | 10:24 AM
blk n tan's Avatar
DGAF- don't give a ****
Old Feb 13, 2010 | 02:35 AM
Amermainipani's Avatar
My wife, three daughters, and other family members are now using Renewed Life acai berry Supplements, and love me for it. I am 68 and feel great.
Old May 5, 2011 | 08:44 PM
GoBigOrGoHome's Avatar
DILLIGAF....does it look like i give a **** thats my favorite
Old Jul 3, 2013 | 10:45 PM
Brodon's Avatar
Yes! I agree,you left out the all importantmivec abreviationlolthis is a mitsu forum right (Mitsubish Innovative Valve timing and Electronic Control system) just thought I'd add the best one......
Old Sep 23, 2016 | 02:52 PM
daem0n's Avatar
Do not forget also BBW
Old Nov 28, 2017 | 06:24 AM
perfectlift-tips's Avatar
Good one mate,
anders_98
Aug 27, 2010 05:54 PM
slow420a
Feb 19, 2008 10:00 PM
RCJr9186
Dec 14, 2007 08:51 PM
Sebba
May 4, 2007 04:04 PM
paintballproam
Oct 31, 2006 05:22 PM
