stock ride height on a 97 GSX
Old Oct 8, 2006 | 09:44 PM
BernaskiBLAZE's Avatar
Default stock ride height on a 97 GSX
can some one tell me where to measure and what the stock ride height is/or should be?
Old Oct 8, 2006 | 09:57 PM
Default RE: stock ride height on a 97 GSX
from the ground tot he car? [:-]
Old Oct 9, 2006 | 03:05 PM
yes from the ground to the car
Old Oct 10, 2006 | 11:35 AM
alittle over 5" i believe.
Old Oct 10, 2006 | 02:02 PM
98eclpsrider's Avatar
do you guys know if the stock ride hight in the front is the same as a dodge advenger?
Old Oct 12, 2006 | 01:10 AM
where is that measured to exacally and if you can how about the hieght of the front and back ( top of the fender to the ground)
Old Oct 12, 2006 | 09:56 AM
i didnt take any measurements. I just found that the ground clearance is listed at alittle over 5"
Old Oct 13, 2006 | 01:27 AM
alright thanx for the info just wanted to know how high my car will be after I get rid of the lowering springs and worn struts
JAMAL
Oct 7, 2009 02:25 PM
richwin
Nov 17, 2007 04:04 PM
2insane
Aug 29, 2006 02:00 PM
zsero
Apr 24, 2006 03:54 PM
Stealth ES Dragon
Dec 10, 2005 10:33 AM
