stock ride height on a 97 GSX
Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in?
Oct 8, 2006 | 09:44 PM
BernaskiBLAZE
Jun 2006
can some one tell me where to measure and what the stock ride height is/or should be?
BernaskiBLAZE
Find all posts by BernaskiBLAZE
Oct 8, 2006 | 09:57 PM
Sebba
Feb 2006
Austin, TX
RE: stock ride height on a 97 GSX
from the ground tot he car? [:-]
Sebba
Find all posts by Sebba
Oct 9, 2006 | 03:05 PM
BernaskiBLAZE
Jun 2006
yes from the ground to the car
BernaskiBLAZE
Oct 10, 2006 | 11:35 AM
TheEngineer
Jan 2006
alittle over 5" i believe.
TheEngineer
Send a private message to TheEngineer
Visit TheEngineer's homepage!
Find all posts by TheEngineer
Oct 10, 2006 | 02:02 PM
98eclpsrider
Aug 2006
do you guys know if the stock ride hight in the front is the same as a dodge advenger?
98eclpsrider
Find all posts by 98eclpsrider
Oct 12, 2006 | 01:10 AM
BernaskiBLAZE
Jun 2006
where is that measured to exacally and if you can how about the hieght of the front and back ( top of the fender to the ground)
BernaskiBLAZE
Oct 12, 2006 | 09:56 AM
TheEngineer
Jan 2006
i didnt take any measurements. I just found that the ground clearance is listed at alittle over 5"
TheEngineer
Oct 13, 2006 | 01:27 AM
BernaskiBLAZE
Jun 2006
alright thanx for the info just wanted to know how high my car will be after I get rid of the lowering springs and worn struts
BernaskiBLAZE
Change tires height
JAMAL
02:25 PM
Antenna height
richwin
04:04 PM
Racing GST Stock vs GSX Stock
2insane
Aug 29, 2006
02:00 PM
Looking For Height Adjustable ECS Struts
zsero
03:54 PM
stock 1989 honda crx si VS stock 1991 Dodge Stealth es
Stealth ES Dragon
10:33 AM
Tags
2g
97
98
clearance
eclipse
eclipses
fender
ground
gs
gst
gsx
height
mitsubishi
ride
stock
Back to Subforum
View Next Unread
is something loose,rear suspension
04:41 PM
