99 eclipse trans fluid and pvc valve
Old Jun 12, 2004 | 11:39 AM
glennsafrit's Avatar
Default 99 eclipse trans fluid and pvc valve
I asked this question in the eclipse folder but no one seems to know so I will try here. On a 99 eclipse in the owners manual it says to use the diamond brand auto transmission fluid that you can only get at the dealer. Surely there is a aftermarket brand that will work just as fine. What is it? Also, where is the pvc valve located on this model. Rs inline 4 Thanks for any info.
Old Jun 21, 2004 | 12:00 AM
ninja_zx7r's Avatar
Default RE: 99 eclipse trans fluid and pvc valve
CHRYSLER ATF CAN BE USED BUT IT HAS TO BE THAT KIND OF AUTOMATIC TRANS FLUID ,THE TRANSMISSION IS MADE BY CHRYSLER SAME AS THE NEON AND AVENGER, THE PVC YOU WILL SEE IT ON TOP OF THE VALVE COVERIS CONECTED TO A HOSE LOOKS LIKE A PLASTIC TUBE CONECTED TO RUBBER HOSE
trainfun
Oct 10, 2019 04:58 PM
newoutlanderfan
May 27, 2013 10:47 AM
jcasaccio
Jun 6, 2006 06:14 PM
urides
Mar 19, 2006 04:29 PM
holdmyhandgary
Jan 4, 2005 10:48 PM
