Trans fluid went into engine. How?
Old Jan 30, 2005 | 07:06 PM
trainfun's Avatar
Default Trans fluid went into engine. How?
This is a follow-up to my earlier post. 97 Spyder GS, 87000 miles.
Auto trans problems. Slow into reverse, then engages with a thud. Bad idle sometimes.
Hit a component with ratchet when tightening battery clamp, it sparked. Thought that might be related. (Please see earlier post on auto trans...)
Then...
I had checked auto trans fluid last week it was OK. Checked it today and fluid was at very bottom of dipstick. But engine oil was way overfull.
Drained crankcase -- got 8 qts. Definitely 2 liquids with different properties draining out.
Changed filter and replaced with 4.5 qt fesh oil.
Added 2.5 qt ATF to trans to bring level to full hot.
Coolant level is unchanged.
Is there a component that could fail and allow engine vacuum to draw off the trans fluid? This used to happen with Corvairs, the vacuum modulator diaphragm would fail and the fluid would be drawn into the engine. But the old powerglide was a lot simpler than the trans in the spyder.
Would appreciate any help.
Thanks!
Old Oct 10, 2019 | 04:58 PM
edpruss's Avatar
Most likely auto trans. Fluid was put in the wrong entry.
ed
MrGrnMitsu
Apr 20, 2014 07:57 PM
newoutlanderfan
May 27, 2013 10:47 AM
jcasaccio
Jun 6, 2006 06:14 PM
allen
May 21, 2006 02:57 PM
larre
Feb 12, 2004 02:15 AM
