is something loose,rear suspension
Old Oct 16, 2006 | 03:22 AM
RamZet's Avatar
Default is something loose,rear suspension
i have a 2000 eclipse and every time i hit a bump it sounds like something is loose back there.anybody know what it is????? it has 80 grand on it
Old Oct 16, 2006 | 10:24 AM
Default RE: is something loose,rear suspension
Probably either a bad tie rod, joint, or sway bar assembly. Try shaking the car and see if you can hear it. Might even be a bad strut.
Old Oct 16, 2006 | 09:03 PM
bud660r's Avatar
how are youre tires? i had the same problem, and when i changed my rear tires every thing went away! if they are bald that might be the problem , also check youre upper controll arm bushing it could be bad and the knuckle could be vibrating on the controll arm! just some things that i went through to stop the banging in my rear susp!
good luck!
Old Oct 17, 2006 | 02:31 AM
RamZet's Avatar
my tires are goodyear low profile and are new,its only there when its a decent bump.sound like someting is jumping in he back by the spare tire but i took everything out of the back and tried it again,still there.the noise sounds like when a shock is loose or the bushing is bad.i read that they(mitsubishi) had complaints about that type of noise in that year but, i dont know what they found out
PalmSprings
Dec 12, 2013 06:52 PM
KentuckyPunk1968
Mar 20, 2012 09:51 PM
rklamka
Mar 15, 2011 08:37 PM
97GSpower
Feb 11, 2006 09:35 AM
t4_gsx
Dec 18, 2005 08:45 PM
