VR-4 stumbles when cold
Old Jul 13, 2004 | 06:29 PM
deadweasel101's Avatar
Default VR-4 stumbles when cold
I have a '92 3000GT VR-4 with a cold engine stumbling problem. The engine starts perfectly hot and cold, but while cold stumbles badly when accelerating through about 2k RPM, with occasional mild backfire in the exhaust. The problem mostly disappears when the turbos kick in, and after warmup, but I can still feel an occasional "hiccup" in the engine while running at constant speed after warmup.
It has 60k miles on it, and I just had the 60k maintenance done, with new timing belt, water pump, fluids, fuel filter, and plugs/plug wires. The problem existed before the service, and I was hoping the tuneup would cure the problem, but it had no effect.
The computer has no codes stored to indicate a problem. The Check Engine light stays off. The air filter is old but still fairly clean. I'm having my mechanic checking fuel pressure this afternoon; if it's not spark, it might be fuel.
miken68
Sep 20, 2008 09:37 AM
midnightD
Sep 13, 2004 11:35 AM
TwiztedEclipse
Mar 13, 2004 02:05 PM
oldmansgs
Jan 12, 2004 09:16 PM
600$eclipse
Apr 20, 2003 05:15 PM
