coolant leak
Old Feb 9, 2009 | 01:26 PM
eldrm's Avatar
Default coolant leak
hi, i've got a montero sport that has developed a coolant leak located underneath ,near the passenger side frame rail, it seems foamy as it drips with the engine running. it also has no heat, although the temp gauge is up. Is there an auto trans fluid cooler in that area?thanks for any info!
Old Feb 10, 2009 | 04:06 PM
eldrm's Avatar
Default RE: coolant leak
heater core up in there? anyone?
Old Feb 12, 2009 | 08:00 PM
eldrm's Avatar
rear heater tubes rusted, bypassed rear heater ,everything is beautiful, thanks for nothin....
Old Feb 13, 2009 | 12:15 AM
challenger4x4's Avatar
Maybe nobody replied because nobody ever had this happen before. I've sure never heard of it and never had it happen to any of the three Montero Sports I've owned. No need to be a dick about it just because nobody was able to help. Jeez.
Old Feb 13, 2009 | 06:49 PM
eldrm's Avatar
well at least i got a reply
Old Feb 14, 2009 | 05:11 PM
trevor425's Avatar
maybe next time instead of sitting down to your computer logging into this site and making 4 posts over 4 different days asking about it, you would just pop your hood and look for where the leak is coming from first!
glad i didnt help you.
Old Aug 7, 2010 | 02:17 PM
jnsluft's Avatar
Default Rear auxiliary heater coolant leak
My '02 Montero Limited has developed the same problem. One day I saw a puddle under the back of the car. A pipe connected to the rear heater core started dripping from the point where the rubber hose is connected to the metal line.
This looks like an easy fix. Hopefully this will help some others with a similar problem. I'll follow up with my solution. Either new pipes from the dealer, bypassing the metal lines with HD heater hose, or possibly bypassing the rear heat altogether.
Shawn
Old Aug 21, 2010 | 07:09 AM
jnsluft's Avatar
The leak has been repaired. It cost me $280 to replace the coolant pipes with new OEM parts. No more drips on the driveway,
Shawn
ron
May 2, 2012 06:08 AM
ruski
Dec 30, 2010 05:32 PM
wega
Sep 30, 2007 11:48 PM
JohnOnt
Oct 28, 2006 05:22 AM
novetek
Feb 20, 2006 04:16 PM
