P0421 Yes i searched..
Old Jul 10, 2009 | 05:47 AM
Schnupper's Avatar
Default P0421 Yes i searched..
So my car is an 03 lancer, has had a p0421 code for a while. I replaced the cat and both o2 sensors and the problem still isnt fixed. Any ideads?
Old Jul 10, 2009 | 08:43 AM
BEAT's Avatar
How many sensors on your car? I thought it was 3 not 2 sensors
Old Jul 13, 2009 | 04:51 PM
the ONLY thing that will cause that is a failed cat.
NOT failed o2 sensors.
Old Jul 14, 2009 | 09:07 AM
BEAT's Avatar
He never answered me back it means he solved the problem.
He said he replaced the Cat Back but still has a problem he probably replaced all 02 sensor.
Old Jul 19, 2009 | 07:39 AM
Schnupper's Avatar
naw it hasnt been fixed. Im still pondering of what it could be.. I tested the tps sensor, checked the spark plugs countless things. Any other suggestions. One thing i noticed which is VERY odd is the downstream o2 sensor is before the cat and not after it. I find that very odd. How is it supposted see if the cat is working or not?
Old Jul 20, 2009 | 08:26 AM
Indy Tech's Avatar
Wink
This code that keeps coming back could be the following.
Aftermarket Cat installed. (These cars need originals)
heated O2s wiring problem check wiring to PCM / ECM
if all checks out good you could well have a bad PCM / ECM
Your cat is up on the exhaust manifold right under the first O2s
if i remember correctly.
Old Jul 20, 2009 | 07:03 PM
you replaced the wrong cat.
the one thats monitored is in the exhaust manifold
Old Jul 20, 2009 | 07:11 PM
X2 on this.
abo1787
Nov 23, 2008 09:31 PM
atown420
Mar 6, 2008 02:02 PM
hawwk11
Nov 3, 2007 10:55 AM
3000gtizzle
Sep 20, 2007 07:23 PM
plaptop
Jul 12, 2007 12:19 PM
