1992 mitsubishi 3000 gt sl not starting
Old Aug 31, 2009 | 03:06 AM
bumpn's Avatar
Default 1992 mitsubishi 3000 gt sl not starting
new ecu was installed about 7 years ago and the car was parked 3 yrs ago until i bought it from my dad. he has put a 200 amp battery charger on it to charge battery a few times but eventually when i got it it needed a new battery as i just replaced.. the car will turn over all day but doesnt seem to have no spark.. the fuel pump doesnt shut off and the injectors seem to stay open and totally flood out all the cylinders as i am flooding the crank case with gasoline.. any ideas on what is wrong and some things i can check and how i go about checking them... thanks
Old Aug 31, 2009 | 08:48 AM
Girly VR4's Avatar
you fouled out the plugs. Swap in all 6 new spark plugs, and you should be OK.
Old Aug 31, 2009 | 12:56 PM
bumpn's Avatar
i just got the new plugs and still no spark and the injectors still seem to keep pouring gasoline into the cylinders.. now my radiator fan keeps coming on and off when i try starting this car. anybody know where i should go and check next? it has a new battery and now brand new spark plugs? also what are some symptoms of a bad ecu?
gpgtp00
Jul 1, 2014 11:35 PM
Monkeymike20
Jun 23, 2011 11:03 PM
stbrian
Nov 12, 2010 10:19 AM
Eggcellent
Oct 12, 2007 05:02 PM
Indecline
Oct 25, 2006 09:20 AM
