Mitsubishi
Old 10-25-2009, 03:42 PM
tulsa44 tulsa44 is offline
Default power antenna on 2002 montero
Has anyone changed this out? I can not find a manual for this and want to know where to start. Uner the hood or under the dash?
Old 10-25-2009, 04:14 PM
redturboeclipse redturboeclipse is offline
Was the search button not working for you?
http://mitsubishiforum.com/forum/sho...hlight=antenna
First link was the thread I recently made.
Jack up the car, remove tire, remove fender liner.
Old 10-25-2009, 04:36 PM
MonteroLTD MonteroLTD is offline
You don't need to remove the tire. Just turn in all the way to the right so you have room. I have big arms and was able to get in there just fine. Otherwise, that's it.
Old 10-25-2009, 05:58 PM
Quote:
great tip.
Old 10-26-2009, 08:36 PM
any ideas of a national parts store who would carry an aftermarket antenna mast for a 2002 montero sport. The dealer here has one for $70, but that seems awfully high for just the mast. The motor works perfectly and I don't want to go through the work of removing it if I can find a replacement mast.
Old 10-26-2009, 11:27 PM
You were a little vague the first time posting, esp on your title.
I hate how the Montero is regularly confused with the Montero Sport. We really need separate forums, but the community itself is dead to even warrant one.
I don't have any experience with the "SPORT"
Did you just pull the antenna and the mast out as the antenna came up? Did it just come up with ease? It maybe different on the sport, because on the regular montero it doesnt come out at least with mine no matter how hard you pull as it comes out. I already removed the broken piece from INSIDE the power antenna assembly.
If you ever get the mast, I would recommend removing the broken piece thats inside the power antenna assembly.
Ebay sells just the mast for cheap if you don't want to go through the dealer
Tags
2002, antenna, mitsubishi, montero, power, removal, remove, sport
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
