Mitsubishi
Old 10-30-2009, 12:07 PM
elkhutr elkhutr is offline
Default 95 still has miss
Ok local dealer has no idea, it went away for one day but it's back, they didn't know if I rebuilt the motor if it would fix it. My maintenance req-light is on. It seems this problem is at low RPM's or when I gas it with the overdrive on it surges or misses unless I keep pressing the gas pedal it goes away. Could it be the ICM? The one day I drove it everything was fine shifted nice, idled fine it was perfect. Also can I use and electrically stuff from a 3.0L Montero to help diagnose the problem or does it have to be a 3.5L?
Old 10-30-2009, 03:02 PM
dsm1990gsx dsm1990gsx is offline
Do you have a check engine light on?
__________________
2003 Ford Escape old ladys car
1990 Tsi Awd DD 12.8 @109.9 s16g @ 22lbs 2.0 60 ft.
1990 Eclipse Gs "The new DD"
hks 264/264, 3" gm maf, maft, dejon tool intake, punishment racing fmic, s16g, 3" tbe, evo 3 o2 housing, 2g ex mani, fic 650's, wally 255, afpr, aem wideband, safc II, logger, polly mounts, act 2100, a/c, cc, p/s and balance shafts eliminated.
Old 10-30-2009, 05:55 PM
might help if you tell us whats under the hood.
Old 10-31-2009, 09:53 AM
no the check engine light is not on. It's a 3.5L.
Old 10-31-2009, 11:21 AM
DOHC or SOHC?
and what has happened up until now? Have you broken a timing belt? How many miles on it? What have you done to it?
you need to give information for people to help.
Old 11-02-2009, 10:24 AM
Injectors cleaned, grounds checks , new coils, plugs, wires, throttle components re-places, 178k miles, timing belts fine, replaced vacuum cv something,
Old 11-02-2009, 07:08 PM
do a compression check.. you will almost assuredly have low compression in one cylinder.
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
