95 still has miss
Old Oct 30, 2009 | 11:07 AM
elkhutr's Avatar
Default 95 still has miss
Ok local dealer has no idea, it went away for one day but it's back, they didn't know if I rebuilt the motor if it would fix it. My maintenance req-light is on. It seems this problem is at low RPM's or when I gas it with the overdrive on it surges or misses unless I keep pressing the gas pedal it goes away. Could it be the ICM? The one day I drove it everything was fine shifted nice, idled fine it was perfect. Also can I use and electrically stuff from a 3.0L Montero to help diagnose the problem or does it have to be a 3.5L?
Old Oct 30, 2009 | 02:02 PM
dsm1990gsx's Avatar
Do you have a check engine light on?
Old Oct 30, 2009 | 04:55 PM
Manybrews's Avatar
might help if you tell us whats under the hood.
Old Oct 31, 2009 | 08:53 AM
elkhutr's Avatar
no the check engine light is not on. It's a 3.5L.
Old Oct 31, 2009 | 10:21 AM
Manybrews's Avatar
DOHC or SOHC?
and what has happened up until now? Have you broken a timing belt? How many miles on it? What have you done to it?
you need to give information for people to help.
Old Nov 2, 2009 | 09:24 AM
elkhutr's Avatar
Injectors cleaned, grounds checks , new coils, plugs, wires, throttle components re-places, 178k miles, timing belts fine, replaced vacuum cv something,
Old Nov 2, 2009 | 06:08 PM
Manybrews's Avatar
do a compression check.. you will almost assuredly have low compression in one cylinder.
The Mayor
Sep 3, 2014 02:39 PM
2nd g eclipse gst
Apr 13, 2007 09:20 PM
racerx55
1st Generation
Dec 27, 2006 11:28 AM
rdwngs444
Aug 20, 2006 01:19 AM
Ancient Mariner
Nov 18, 2005 09:29 PM
