4WD does not engage
Old Nov 1, 2009 | 05:27 AM
Skiddy's Avatar
Default 4WD does not engage
When I switch to any 4WD position from 2H, I get flashing lights (they do not stay on). If I switch back to 2H, they stop flashing. I have a feeling the offending part is the free wheel switch, as this hasn't ever been changed on my vehicle and it's 10 years old. But I was wondering if anything else could trigger this issue? Thanks!
Old Nov 3, 2009 | 06:30 PM
CerneDef73's Avatar
Thanks for that Mike, its not full time 4WD does that make any diference? So when you say the centre diff is locked does that make all 4 wheels drive at the same time and when thats not on they drive sepretly?
Old Nov 5, 2009 | 09:58 PM
jgbrules's Avatar
if the lights flash, you have a trouble code that will help you diagnos the problem. you can find the codes for the 4wd in the ABS ecu. most of the time its one or more of the switches on the transfer case.
seehow
May 12, 2015 05:08 PM
Dsmoovy
Nov 21, 2011 03:00 PM
myersbr2
15
Nov 8, 2010 01:49 PM
mhansen262
Nov 29, 2008 09:18 AM
rbhylland
Jan 1, 2006 03:22 AM
