Remove Crankshaft pulley
Old Nov 8, 2009 | 11:08 PM
Douglas McKibbin's Avatar
Red face Remove Crankshaft pulley
Changing out the timing belt on my 1994 3.5L Montero. I have removed the crank pulley bolt but I cannot remove the pulley. No bolts holding the pulley. Does it come off with a gear puller? I seem to be able to pull the pulley put about 1/4" but I notice I am pulling out the timing belt gear also ( I am not sure but I thing this gear is part of the crankshaft proper ). Am I missing something?
Old Nov 9, 2009 | 08:40 AM
jason clipse's Avatar
u usually need a puller to pull a crank pulley off.
Old Nov 9, 2009 | 11:00 AM
jrmdir's Avatar
Timing belt gear is attached to the main pulley with small roll pins. May separate during removal but can be put back together before reassy. My whole assy came out in one piece without using a puller but maybe I was lucky.
Ron
Old Nov 10, 2009 | 08:14 PM
I tried pretty hard with a puller and the thing didn't budge. Is it OK to heat the pulley or might I damage something about the balancer?
Old Nov 12, 2009 | 01:57 PM
jrmdir's Avatar
Did you remove the crank position sensor?
Ron
Old Nov 16, 2009 | 10:35 PM
myfyn69's Avatar
If you know someone that has a "Morgan knocker" its a body dent puller tool you have to be very very careful but yes it will work. I rented a puller from Auto zone a parts place in Oregon to do mine but used the Morgan knocker in the junk yard and that one came off easy. If your in the Portland Oregon, area I will let you use mine. The balancer is sometimes made with a glue as like on the Eclipse, Talons, and Lazers and if yours is don't heat it up it can seperate like they do.
Old Nov 22, 2009 | 03:05 PM
Smile Answer my own question
Once I heated the crankshaft and loosened the timing belt, and allowed the crankshaft to cool, the pulley literally slid off. I had tried hard prior to this to pull the thing off with a 5 ton puller. It was a rebuilt engine, so it could have been teated with locktight or something.
Old Nov 22, 2009 | 04:45 PM
jrmdir's Avatar
"and loosened the timing belt.........."
Were you really trying to remove the pulley with the belt still on and tight
Anyway - glad you finally were able to remove it.
Ron
jx_mirage01
Jun 14, 2008 09:02 AM
Angelonia
Nov 15, 2006 04:05 AM
jacek
Dec 25, 2004 01:26 AM
LIQUIDSMILE
Jun 16, 2004 04:36 PM
03eclipseGT
Oct 6, 2003 08:43 PM
