Rebuild help?
Old Dec 2, 2009 | 11:27 AM
blackstealth11's Avatar
Default Rebuild help?
OK i recieved a 1992 dodge stealth twin turbo. AWD. for free from a friend the engine has a knock. the vavle cover gasket blew and covered the clucth in oil. anyway i got the engine out of it and am looking for good rebuild kits. i found some on ebay for like $500 but i dont know if there any good. I drove a civic before so im new to this car. If any one could give me some direction on what to do to make this car run again and bereliable i would appriciate it.also im looking for a good clucth but not sure what to get i was planning on getting some stuff from 3sx.
thanks
Old Dec 2, 2009 | 05:39 PM
Girly VR4's Avatar
you're honestly better off buying a used replacement engine.
Old Dec 2, 2009 | 06:37 PM
Default rebuild
why is that are those engines expensive to rebuild. i saw some engines at tigerjapanese.com are these engines any good.
Old Dec 3, 2009 | 09:55 AM
Girly VR4's Avatar
I have no idea what tigerjapanese is, never dealt with them.
Rebuilding from a spun bearing is a LOT of work (re: what causes the knocking sound you hear), and parts are expensive, and these engines are VERY finicky, and have a low threshold for mistakes. The crankshaft alone is $750-$800 from the dealer, and that's just one part you need to replace.
The cylinder walls could be scored, bent rods, metal shavings in your oil pan. Everything needs to be disassembled, checked, cleaned, rechecked, re-cleaned, rechecked again, assembled, disassembled and check the clearances, reassembled, cleaned some more, replcae the oil cooler, oil pump, oil pickup tube, bearings, possibly rods/pistons, and after all of that, you're spending close to $3k in parts.
Just buy a good used engine/oil cooler, for like $1500, drop it in, and call it a day.
Old Dec 3, 2009 | 11:47 AM
Ok yeah that makes since.
Old Dec 3, 2009 | 12:27 PM
OK then does any one know a good site where i could just buy the engine not a engine/transmission combo.
Old Dec 6, 2009 | 10:27 AM
Girly VR4's Avatar
some of those jdm places on e-bay have some good deals.
AznLibra929
Aug 6, 2007 08:45 PM
fst2qtrmile
Jan 9, 2005 07:24 PM
promxz24
Oct 20, 2004 07:36 PM
rx7_punk
Sep 2, 2004 01:24 AM
BETTYSDADA
Feb 24, 2004 03:54 AM
