Engine fuse keeps blowing
Old Jan 16, 2010 | 03:24 PM
pomerjon's Avatar
Default Engine fuse keeps blowing
I was driving my eclipse and it would buck everytime I shifted gears, then it died. After it sat in a garage overnight I tried to start it, and it took a few seconds but started and ran. After that it ran fine but took 5-8 seconds to turn over. THen it died again a month later and did'nt start again. Someone said to replace the fuel pump, so I took out my back seat and put a new pump in and still nothing, but i noticed a lose wire going to the conector on the top of the pump so I wired it it better and still nothing. Thats when I check the relays and saw that the engine fuse was blown, so I replaced the fuse and it started up after 3 sec of cranking probably building the pressure back up. It idled for a while so i pulled it out of the space and stopped and when I tryed to pull onto the road the engine fuse blew when i gave it gas and let off the clutch. Now the fuse pretty much blows as soon as I try starting the car. Any ideas or anyone know of any common thing that could cause this? It is a 95 GS MT.
Old Jan 17, 2010 | 10:57 AM
Is the car stock or is there a lot of aftermarket stuff wired in?
Old Jan 19, 2010 | 01:49 AM
pomerjon's Avatar
Only aftermarket thing i got that has wires, would be my dvd player which wires in the same as a cd player.
stp135
May 27, 2022 09:50 PM
litildevil75
May 2, 2016 07:25 AM
97SRMontero
Apr 15, 2013 07:04 AM
The Bassist.
Aug 31, 2009 10:08 PM
BlackGalant
Apr 24, 2009 07:40 PM
