7-bolt to 6-bolt checklist
Old Jun 25, 2010 | 03:28 PM
tpl6's Avatar
Default 7-bolt to 6-bolt checklist
Alright so I am finally fulfilling my dream of upgrading from a 7-bolt to 6-bolt crank engine as a graduation present from my entire family. I'm working with a 1996 Eclipse GST 5-speed. I need to know what other parts i will need, or what needs to be changed. I tried the forum search and all i found was basic questions like why change? if i should change? etc...
So my questions are:
what components, outside of the engine itself, will i need to do the full conversion? i.e. transmission parts, changing engine components, etc...
are there any tricks that the service manual might not mention about taking the engine/transmission out (i have a spyder if that matters)?
and finally (i'm starting my persuit for my masters starting this fall) what turbo would be the ideal upgrade for a small budget? 14b? 16g?
thanks a ton
Old Jun 26, 2010 | 07:07 PM
Old Jul 12, 2010 | 09:07 AM
tpl6's Avatar
thank you thats perfect...
just a few more questions:
-Does the 6-bolt (1G) engine bolt right up to the 2G bell housing on the tranny?
-Are the throttle bodies for the 6-bolt and 7-bolt the same? Asking to see if there are any modifications that are needed to the 6-bolt throttle body to match up with the 7-bolt intake from the intercooler...
-Do I need a 6-bolt crankshaft position sensor? or can I use the 7-bolt?
-Is the 7-bolt tranny completely compatible with the 6-bolt engine, after getting the 6-bolt flywheel?
Thank you
jkmd6c
Dec 21, 2007 11:01 AM
red93gs
Nov 30, 2006 02:56 AM
bud660r
Aug 31, 2006 07:41 PM
petro4411
Dec 5, 2005 01:42 PM
antomx
Sep 29, 2004 02:32 PM
