2001 Montero Sport Idling
Old Sep 5, 2010 | 04:20 PM
cancab's Avatar
Default 2001 Montero Sport Idling
I do have a 2001 Montero Sport 4wd Limited. I'm experiencing idling problems. What happens, when the engine is cold and i crank the engine it does not run (. I have to press the throttle pedal a bit and then crank the engine, fine. I have to keep the foot on the pedal at about 1000 rpm until it warms up a bit and then i can leave the pedal. If i crank without my foot on it, i won't run.
It suppose to run when i crank it at first time and keep a bit accelerated and as the engine warms up, the rpm drops to the idle settings/rpm.
Any thoughts/help on it. No codes stored.
Old Sep 5, 2010 | 04:56 PM
Obakemono's Avatar
Idle control motor not working?? Anyone else??
Old Sep 7, 2010 | 12:14 AM
spetznazer's Avatar
what engine? 6g72 or 6g74? Milege? when last time was serviced or tuned up?
metalmtb
Nov 9, 2021 11:00 PM
wilgoo50
Nov 5, 2011 07:06 PM
azsungal77
May 22, 2011 01:59 AM
k_kay
Mar 26, 2010 06:43 AM
ac777
Dec 5, 2007 04:25 AM
