1 G Eclipse tranny help
Old Oct 17, 2006 | 09:34 PM
keithscianna's Avatar
Default 1 G Eclipse tranny help
My 93 sometimes grinds when i put it into first, Other times it goes in perfect. The clutch feels fine just kind hard and no other gears grind at all. If i down**** into first it will always go in, but if i am stoped and try to put it in it sometimes grinds alot. i just got the car so i am not sure if this is how they all are. Also i had to put clutch fluid in yesterday it was bone dry in the res.thanks,
Old Oct 17, 2006 | 09:40 PM
Default RE: 1 G Eclipse tranny help
Ok you need to flush out your clutch lines and fill it up with new fluid + bleed it Also you might want to change your tranny fluid
If you do all that and still cant get in gear then your 1st gear syncro is gone. But i think you should do those ^^ first. I think that will fix your problem.
If it does turn out to be your tranny itself you have many options. You can rebuild the tranny (cheapest option) you can buy a rebuilt one or you can buy a brand new one.
Old Oct 17, 2006 | 11:22 PM
Dookitchen's Avatar
I had the same problem with my tranny when I first bought the car. The previous owner totally didn't take care of the care. The third day I had the car it sounded like what you have described and then 2 days later my buddy and I jacked up the car and guess what.......You ready for this?.........................A crack on the bottom of the Tranny about 4 inches by 5 inches. With a light touch of my magic middle finger that **** fell off and the oil just poured down. That's what happened to mine....hopefully yours doesn't do that or not even the tranny coz it cost me 1000 to get a used tranny. Now the car works good after putting about 3000 dollar job on it.
ECLIPSE GS 1995
Old Oct 18, 2006 | 12:35 AM
daamnn,
Well i hope it is the first one! how much was the labor on the tranny job?
There is one for sale localy for 200 that had 15000 on it
Old Oct 18, 2006 | 01:34 AM
Nubiebubie_GSX's Avatar
i have a 2gen and my first gear is messed up like that also.. Buti can't even down **** to first most of the time. Lately at a stop or a slight roll if i try to go into first it just pop back out or i can feel it grinding or clunkin. All other gears are nice and smooth..
Old Oct 18, 2006 | 02:52 AM
Will a AWD trany fit? Is there a difference?
Old Oct 18, 2006 | 02:58 AM
Would it be a good idea to get one form a junkyard?
is there a way you can tell if the syncros are blown?
Old Oct 18, 2006 | 10:44 AM
No an AWD tranny wont fit sorry im retarded.
Old Oct 18, 2006 | 12:19 PM
im pretty sure an AWD tranny isnt gonna fit for a FWD car
Old Oct 18, 2006 | 12:32 PM
Sorry im retarded
