1991 ECLIPSE LOSS OF POWER
Old Jan 5, 2006 | 01:49 PM
HARMINATOR's Avatar
Default 1991 ECLIPSE LOSS OF POWER
This doesn't happen all the time, so it is hard to recreate.
When I am driving sometimes I will press the brakes to slow down or stop. I will have a short loss of power (1-2 seconds), where I will lose dash lights, radio, ect. Then everything will come back on. Doesn't seem to matter if I am in gear or not (has happened both ways). I have also been able to idle, increase the RPMs (above 2), take foot off the gas, press the brakes & lose power that way. I have noticed a high whine thru the speakers correlating to the RPMs. But like I say, this doesn't happen all the time.
Rarely I have been unable to start the car, no power what so ever. Wait a little bit & then it starts.
What I have tried already:
Replaced the battery.
Replaced the Starter.
Disconnected the radio.
Disconnected the alarm.
Anyone run into this situation before?
Thanks
Old Jan 5, 2006 | 02:36 PM
Patrick's Avatar
Administrator
Default RE: 1991 ECLIPSE LOSS OF POWER
it sounds like you have a short in the electrical system. it always happens when you hit the brakes?
Old Jan 5, 2006 | 03:30 PM
HARMINATOR's Avatar
It doesn't happen all the time, thats the wierd part. Hasn't happened at all this week.
But when it does happen it is only when the brakes are pressed. It doesn't do it at normal driving or at idle conditions.
Thats also only when I notice the high pitched whine (when it's about to happen). So I know now if I hear the whine that when I press the brakes I will lose power for a couple seconds.
Old Jan 5, 2006 | 06:38 PM
Patrick's Avatar
Administrator
does it have a gauge to indicate if it is charging, or just an idiot light?
Old Jan 5, 2006 | 07:47 PM
HARMINATOR's Avatar
Just the idiot light. Not on.
Also, just noticed an error in my original post:
I replaced the alternator NOT the starter [:-]
Old Jan 5, 2006 | 07:56 PM
Sanguinius's Avatar
The high pitch whine in the speakers sounds like a grounding issue... Possibly a loose or broken ground? Sounds like it might be arcing in the wire where it's broke and sometime it's just in the right position to break circuit when you hit the brakes but then comes back up when you let up? Just hazarding a guess here.
Old Jan 6, 2006 | 01:03 PM
HARMINATOR's Avatar
Ok,
I'll check my ground wires this weekend.
Thanks
Old Jan 6, 2006 | 04:19 PM
Sanguinius's Avatar
I'm just going by the whine in the speakers usually that indicates a bad or incomplete ground. So let us know if that helps you at all. Make sure that the frame has a good ground to the battery as well as the engine grounded to the frame.
Old Jan 10, 2006 | 01:52 PM
HARMINATOR's Avatar
Ok,
I checked the ground wires this weekend. Didn't notice any frayed wires or loose contacts. Cleaned a couple of the contacts. No problems the last 2 days. We'll see if this did the trick!
jdohe
Dec 12, 2010 07:00 AM
Buckeyejack
Feb 24, 2005 07:28 AM
Buckeyejack
Feb 22, 2005 04:44 AM
VR4Restored
Aug 14, 2004 01:09 AM
Watson
Aug 10, 2004 10:26 AM
