1993 eclipse starting problem
Old Jan 21, 2012 | 02:30 PM
beansizme's Avatar
Default 1993 eclipse starting problem
i've got a 93 eclipse with a 1.8 and a 5 speed - the cel came on and the engine didn't want to idle - idles very slow - now, it doesn't want to start - acts like it's not getting any fuel - i can hear the fuel pump relay clicking on, but the engine starts and dies numerous times until it finally will run - any suggestions? also, the codes are 21, 25, and 13 - coolant temp sensor(i replaced it) baro sensor and intake air temp sensor
Old Jan 23, 2012 | 08:09 PM
dsm1990gsx's Avatar
Are you still getting a cel after replacing the coolant temp sensor?
Old Jan 24, 2012 | 07:51 PM
beansizme's Avatar
Default hard start
yeah, coolant temp sensor didn't change anything - thinking i might have an ecm prob as these codes all occur at once, but would like to verify that before i pull the trigger on buying one
carter
14
Aug 31, 2015 10:41 PM
Energyrick
Sep 20, 2010 08:27 PM
jsindude
Aug 29, 2007 07:23 AM
wiggerman8860
Feb 19, 2006 03:53 AM
jcp3alex
Sep 27, 2005 10:17 PM
