91 2.0 starts missing at 3800 rpm.
Old Aug 28, 2007 | 10:48 AM
Boevo's Avatar
Default 91 2.0 starts missing at 3800 rpm.
Guys I have a 91 eclipse n/a 2.0 I've raised the idle to 1000 to 900rpm.
Starts great runs good until about 3800 3900 rpm then it starts missing bad like the timing or fuels is being cut. New plugs and wirers.
Any help would be much appreciated.
Thanks
Old Aug 28, 2007 | 11:29 AM
Default RE: 91 2.0 starts missing at 3800 rpm.
Check for a vacume leak... and check the condition of your spark plugs and spark plug wires
Old Aug 28, 2007 | 11:35 AM
jason clipse's Avatar
check if injectors are clogged run some cleaner thru there
Old Aug 28, 2007 | 11:41 AM
Clogges injectors dont do that
Old Aug 28, 2007 | 01:40 PM
Boevo's Avatar
New plugs and wires.
There is no cap and rotor just four coil packs that the plug wires go into.
I'll check for vacuum leaks I just change out all vacuum lines.
But thanks for the fast replies.
Old Aug 28, 2007 | 01:41 PM
racerx55's Avatar
tell me whens the last 2.0 you seen with a distributor... pay attention..
im betting on clogged fuel filter/ low pressure, maybe a bad cat, or the MAF is takin a crap if theres no leaks between it and the motor.
th3thc
Aug 18, 2010 11:21 PM
Daco
May 6, 2009 10:04 PM
xclr8
Sep 20, 2005 10:45 PM
muddyjoe
Jul 9, 2005 10:54 PM
enzo_hashmat2006
Jul 9, 2005 06:28 PM
