93 GS 2 wheel drive brake caliper
Old Sep 12, 2005 | 01:16 PM
Nuggethead 420's Avatar
Default 93 GS 2 wheel drive brake caliper
Huge problem. Change the rear brake calipers but not the mount and there is about .007-.010 play in the bushings and caliper. This created a huge problem with the caliper knocking around while driving at slower speed. It will also create a lock up condition if it ***** enough.
I contacted Cardone the manufacturer of the caliper and they say that the spec is correct. .007 is the worst case but within spec.
I think as an engineer that this would be wrong especially for something that critical. more like .002 max.
Any help would be awsome.
Old Sep 12, 2005 | 02:29 PM
Patrick's Avatar
Administrator
Default RE: 93 GS 2 wheel drive brake caliper
i am not certain what your issue is...the caliper is moving on the mount, or the moving part of the caliper has too much play in it?
Old Sep 13, 2005 | 11:39 AM
The bore in the caliper is larger than the bushing causing a lateral wobble and knocking when the rotor rotates.
the caliper comes in 2 parts the mount and the caliper I replaced the caliper and it was to be OEM spec but it was not, because the Original that I took off due to locking up did not have play between the bushing and the bore.
Old Sep 13, 2005 | 01:37 PM
slow420a's Avatar
Return the caliper and buy a better quality one.
Old Sep 27, 2005 | 04:58 PM
Who is going to give me the extra money for that and lend me a car while I return it and wait for the new one to show up?
I contacted the manufacturer and they sent an in spec caliper that now works awsome.
Going to the source does wonders
Old Sep 27, 2005 | 05:19 PM
Sanguinius's Avatar
Yeah you should always go to the source a customer source guy isn't gonna know shyt about cars and why they do what they do. Cordone is one of the companies that I don't care to deal with (I worked at a shop and we got thier parts all the time).
sk8dudety
May 31, 2014 08:55 AM
Laoshu
Dec 8, 2006 12:09 AM
jdm2ner
Aug 26, 2006 12:20 AM
trbodsm997
Dec 25, 2004 01:52 AM
Ace2133
Sep 7, 2004 10:44 PM
