anyting else i should do?
Old Sep 22, 2007 | 10:44 PM
nick_200321's Avatar
Default anyting else i should do?
hey, i bought my clutch today when i took evrything off, my flywheel was OK just needed the shiny layer taken off from the bad clutch, i went ahead and took advice i was told and used the 220grit wetdry and 400grit sandpaper and perfected it, it is smooth as can be.. i was just wondering.. is there anything else i should do while i have it down so i can save taking it down again?
OH and, you guys say 6 or 7 bolt flywheel.. is that just with the 2.0 cuz mine is a 1.8 and i only have 5 bolts holding the flywheel on.. There are 6 holding on the clutch and pressure plate but only 5 bolting up the fly.. is that normal?
thanks in advance for any help/info
Old Sep 22, 2007 | 10:50 PM
Default RE: anyting else i should do?
Yes thats normal. 6 or 7 bolt refers to the GST/GSX
Nothing else to do, however sanding the flywheel is stupid. It needs to be machined at the very least. If not replaced.
Old Sep 22, 2007 | 11:55 PM
it was perfectly smooth, i just wanted to get the little residue or whatever you call it off. im replaceing the TOB Pressure plate, clutch and of course oil... also gonna change the engine oil in it, i bought some better oil today..
Old Sep 23, 2007 | 10:37 AM
Smooth isnt the point. The point is to remove the surface cracks. By sanding it that doesnt do ****
Old Sep 23, 2007 | 04:07 PM
ComposeEvo's Avatar
sebba is absolutely correct, you need to resurface the flywheel, not so much so it can be "smooth" but for it to be level, and maximise clamping for of the pressure plate.
Take it to a shop where a machine resurfaces it, or buy a new one. If the heat checks are too deep, and theres a ring from the pressure plate, it might be too late. Hopefully your sandpapering didn't etch into the flywheel.
Good luck
Gus
Old Sep 23, 2007 | 05:35 PM
i used 400grit on it which is extremely smooth.. but the flywheel wont come off...so yea, look at my ther post for more information.. the post labeled take apart again
Old Sep 23, 2007 | 05:37 PM
Its because rust has fused it. Just tap it with a rubber mallet
Old Sep 23, 2007 | 06:29 PM
alright, i have to take the tranny off again tomorrow, ill try to get the fly. off again, before i waste the money on a mechanic though imma take a straight edge and filler gagues and see if it is at all warped.. it should be ok though, metal never rubbed
Coqui_Mitsubishi
Jun 12, 2014 10:05 PM
JunebuG35
14
Oct 30, 2006 03:37 PM
bubba
24
Mar 1, 2006 10:51 AM
*~Daaaamn~*
Feb 3, 2006 03:19 PM
jeffery0266
Jan 26, 2006 06:18 PM
