burning oil, @#$&
Old Jun 19, 2007 | 12:55 AM
BoostNightRanger's Avatar
Default burning oil, @#$&
The other i was in the drive thru and noticed blue-ish smoke coming out my tailpipe just after some hard acceleration. A few days later my friend was following me and said he also saw blue smoke come out when i took off. I figured this was my car burning oil but if it isnt what is it and how expensive would it be to fix this? My 91 talon only has 71k on it so even though its old all the parts aren't too worn.
Old Jun 19, 2007 | 01:04 AM
Default RE: burning oil, @#$&
Depending what the problem is.
First, do a compression test and get back to us with some numbers
Old Jun 23, 2007 | 10:39 PM
mxmikie's Avatar
valve stem seals
Old Jun 24, 2007 | 02:30 AM
racerx55's Avatar
mines doing that, turbo is leaking oil on my car.... youll have fun tracking down the problem.
where are you from?
Old Jun 24, 2007 | 12:32 PM
Some other guy who worked on dsm's a lot said the valve stem seals were most likely the problem. If so how difficult is this to fix if you want to do it yourself? As for you Racer im from Madison, Wisconsin, yourself?
Old Jun 24, 2007 | 09:13 PM
racerx55's Avatar
im thinkin you gotta pull the head to do valve seals because you cant get a spring compressor in there.
pullin the head is the safest way anyway. im from ohio, i seen a car the other day that looks like your avatar thats why i was wondering.
Old Jun 24, 2007 | 11:17 PM
Alright ill look into that. But ya man Ohio, its all in the midwest .
Old Jun 28, 2007 | 09:50 PM
mxmikie's Avatar
i have the tool to do them on the car all you need is a air compressor i've done 1.8-2.0-2,4 and 3.5 dohc on the car
Old Jun 29, 2007 | 02:15 AM
racerx55's Avatar
i was thinking of my dodge peon motor when i said that, looks like theres more room on the 4g63
lack of sleep tends to do that [>:]
Old Jul 4, 2007 | 11:32 PM
Im going to do those seals tomorrow i think.How long/doable is this if youre ado-it-yourselfer?
cdvyas20
Feb 19, 2013 06:24 PM
rapperbasher
May 7, 2007 02:53 PM
monterodude
Dec 18, 2006 02:33 AM
WhiteTrash93
1st Generation
11
May 20, 2006 12:44 PM
shivan15
Oct 19, 2005 03:27 PM
