dead
Old Mar 1, 2006 | 10:26 AM
93eclipsegsx's Avatar
Default dead
ok, i took off the alternator off last night and before i did that i accidentaly dropped a ratched and it arc'd off of the alternator. now that i have it all put back together i went to start it this morning and it wont start. i checked the battery and it reads 12v and i tried the alternator and its at 0. is it a possible fuse that went bad? or a bigger issue.
Old Mar 1, 2006 | 10:28 AM
slow420a's Avatar
Default RE: dead
My guess is a fuse
Old Mar 1, 2006 | 10:35 AM
Default RE: dead
if the battery puts out 12 volts then wouldn't the car start on a bad alternator, i thought the alternator was there to keep the battery charged, if so then the starter might be bad.
Old Mar 1, 2006 | 10:47 AM
Default RE: dead
thats what i thought to but my uncle called one of his buddy's who work for the city, and he said if i blew a fuse on the alternator, it still wont start. like all it does is click and thats it and sometimes if i take the key out, the idiot lights will sometimes still be on.
Old Mar 1, 2006 | 10:58 AM
Default RE: dead
well i guess then just check the fuses and check the wire connections and let us know how it goes.
Old Mar 1, 2006 | 01:30 PM
99clipsgst's Avatar
Default RE: dead
If all you hearis a click then the starter could of gone bad.
Old Mar 1, 2006 | 02:26 PM
spyder86's Avatar
Default RE: dead
I agree with TheEngineer, if your battery is reading 12v then the car should start, the alternator just acts like a generator to charge the battery, not start the car. I have driven around with a dead alternator before, not very long, but I still did. It could quite possibly be the starter.
Old Mar 1, 2006 | 08:05 PM
Default RE: dead
well the battery was dead, it was reading 12v but i guess its the amps that matter's. BTW it only took 8 hrs to figure that one out. and thank's ESTRAW for coming over and helping out.
Old Mar 1, 2006 | 08:50 PM
Sanguinius's Avatar
Default RE: dead
I was going to actually say the same thing but glad you found the problem (Next time disconnect the battery ffirst but ensure you have your radio code).
KF97diamonte
May 5, 2010 01:38 PM
vertigo14k
Feb 23, 2006 01:09 AM
darklibra83
May 30, 2005 12:53 AM
onsse
Mar 18, 2005 10:54 AM
jscopus
Oct 28, 2004 04:06 PM
