fuel pump
Old Jan 24, 2006 | 05:58 AM
DSMTalonAWD51's Avatar
Default RE: fuel pump
fpr is under the hood on the fuel line next to the injectors. you can get away without buying one, if anything your car is just going to run a little rich. but when you start raising the boost, buying bigger injectors, and tuning, you going to need one for sure
Old Jan 24, 2006 | 05:10 PM
brandoN^gsT's Avatar
Just replaced my fuel line, and I had to buy another one (Used for $45 from a gut yard). What you do is you use a locking wrench, and then the proper sized wrench, and grip them, and try to squeeze them together, and it will loosen up. Good luck.
-brandoN^-
Old Jan 24, 2006 | 08:05 PM
93eclipsegsx's Avatar
thanks for all the help guys i appreciate it very much!!!
Old Jan 24, 2006 | 09:57 PM
Sanguinius's Avatar
Hopefully it works. I dunno I always just drenched the locked section in WD-40 or some other penetrating oil let it soak a few hours then try breaking it free.
MNalfa
17
May 9, 2019 06:07 AM
Germankat
Mar 19, 2008 05:28 PM
Germankat
Mar 19, 2008 06:43 AM
agallardo
Feb 22, 2007 03:46 AM
audionxs
Sep 19, 2003 11:56 PM
