timing
Old Jan 25, 2006 | 12:54 AM
93eclipsegsx's Avatar
Default timing
ok, after i put the second head on my car in the last month, it started right up and after a couple seconds it was making a high pitched squeling noise. so i turned my car off and i havent started it up again, because i didnt want to hear that obnixhous noise again. anybody ever heard of anything like that.
i put a new timing belt, belt tensioner, and idler pulley on it also.
Old Jan 25, 2006 | 03:19 AM
DSMTalonAWD51's Avatar
Default RE: timing
belt may be too tight
Old Jan 25, 2006 | 01:56 PM
NESpeed's Avatar
Default RE: timing
When was the last time you replaced the water pump? Also take or rent a mechanic stethoscope and try and pinpoint the noise and let me know. Its hard to over tension a belt with a semi auto tensioner.
Old Jan 25, 2006 | 03:08 PM
Sanguinius's Avatar
Default RE: timing
Squealing could be anything from the accessory belt not being tight enough to the bearings going in a water pump, power steering pump, or alternator. Get the mech steth and start checking those things.
Old Jan 25, 2006 | 04:18 PM
estraw's Avatar
Default RE: timing
it shouldn't be the water pump, we just replaced that a month ago, it probably doesnt even have 100 miles on it if he drove it at all
Old Jan 25, 2006 | 06:05 PM
NESpeed's Avatar
Default RE: timing
Wow Sanguinius do you read these posts???
Old Jan 25, 2006 | 08:08 PM
Default RE: timing
there are no accessory belts that were running, the only belt that was running was the timimg belt. no alternator, no water pump, no a/c, power stearing. im to frustrated, i think i might tow it to the dealer b/c it is all torn apart, all theyll have to do is throw the belt on.
Old Jan 25, 2006 | 09:53 PM
NESpeed's Avatar
Default RE: timing
All I can say is get the sound on video and either post it or email it to me.
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
