Idle air
Old Oct 15, 2007 | 03:52 PM
superhumankiddy's Avatar
Default Idle air
What's up guys, I was wondering, my car still has it's idle surge and I have replaced the isc and the ecu and blocked off the egr. All I have left to think of is a vacuum leak. Is there anyway anyone could tell me how to check for a vacuum leak and which lines I need to check for that. Also, someone told me something about a idle air control circuit, I was wondering if anyone knew what that was and if you could tell me where it is how to test it, or if it's what I have already checked. Thanks to everyone.
Old Oct 15, 2007 | 05:28 PM
93eclipsegsx's Avatar
Default RE: Idle air
did you try replacing the iac?
Old Oct 15, 2007 | 06:47 PM
What is that? I replaced the ISC if that's the same thing. It was on the TB, under the intake hose elbow.
Old Oct 15, 2007 | 10:05 PM
did it have a square like connector?
Old Oct 16, 2007 | 02:39 PM
Yup, with 6 prongs in it, and it has like a punger thing on it that goes in the TB and is supposed to move in and out. Mine doesn't move in and out though, so I'm wondering if there might be a problem with the wiring? I took it out and watched it, and had someone turn the key from acc to on without starting the car, and it vibrated but didn't go in and out, both of the ones did it, the one that I had on there in the first place (a black one) and the one I replaced it with (a brownish one). I've noticed that it's worse when it's cold, when I first turn it on when it's warm, it idles up to about 2,000 RPM for a couple seconds, then start surging from about 1200-1500 RPM at a slow steady speed. When it's cold, it idles up to about 3 to 3500 RPM and stays there for about 10 seconds maybe, then starts surgingat a fast and not too steady speed. So I'm wondering, could it have something to do with the FIAV? I'm almost out of options. Thanks.
Old Oct 16, 2007 | 10:35 PM
mxmikie's Avatar
tps
Old Oct 17, 2007 | 01:47 PM
Whats the tps? And where is it located?
Old Oct 17, 2007 | 05:29 PM
SILVER's Avatar
get a can of eather (starting fluid) and spray it around your vaccume hoses & intake manifold. If there is a vaccume leak, the engine will bog down, and you will know what area to look at more closely.
ORIGINAL: superhumankiddy
yamahablaster8230
Aug 29, 2006 09:28 AM
1398spdr
Mar 16, 2005 07:29 AM
gsr94trycatchit
Dec 19, 2004 07:27 AM
