idleing too high
Old Apr 25, 2006 | 04:02 AM
BrunoBoy650's Avatar
Default idleing too high
ok my 1g gsx was idleing yesterday at 800-1000rpms, just normal, and today it was between 1200-1900 rpm, idk y, but my oil is BLACK, but can that have anything to do with it?
Old Apr 25, 2006 | 07:05 AM
Default RE: idleing too high
Mine idles that high when its really cold. Change your oil too.
Old Apr 25, 2006 | 12:23 PM
ORIGINAL: Sebba
but the temp gauge reads middle
Old Apr 25, 2006 | 12:34 PM
oh... well you need to change your oil. When ever your oil is not a golden/brown you need to change it. You can ajust your BISS screw that is under a plastic cap on the throttle body. Its very very very common. Try searching a little.
Old Apr 25, 2006 | 01:23 PM
thanks, but a quick Q', how does it just turn up on itself? and do you have any pics of where this screw is.
Old Apr 25, 2006 | 03:01 PM
did you do any mods before the problem started? you might have a boost leak that will cause a high or low and bouncing idle
Old Apr 25, 2006 | 03:54 PM
Mayb a boost leak, ill ask the shop, but I know I need to do a oil change because it is pitch black, and my oil gauge is usually at L to the first notch but now its rising to like the middle and going higher
Old Apr 25, 2006 | 09:10 PM
nvm lol, i went to the shop and they found it was a broken wire.
BLAZE GS
Apr 29, 2008 06:41 PM
SILVER
1st Generation
Aug 11, 2007 01:21 AM
96gstspyder
Jan 17, 2007 12:36 PM
boo426666
Oct 19, 2006 05:58 PM
99EclipseRS
Jan 20, 2005 03:57 PM
