interference motors
Old Oct 3, 2008 | 06:54 PM
methanol_manic's Avatar
Default interference motors
as you all know... i blew my head gasket and my head is fuked... but i have one question is the 1g 4g63 and interference motor and if so would a blown head gasket cause major damage... thats what i hear and i just thought id ask....
Old Oct 3, 2008 | 08:16 PM
estraw's Avatar
Default RE: interference motors
yes its an interference motor, and no it shouldnt really cause any damage. the only thing that would concern you with an interference motor is if your timing belt snapped. and how do you know that your head is fukced?
Old Oct 3, 2008 | 09:01 PM
dsm1990gsx's Avatar
Yes its interfernce and blowing a head gasket wont bend valves.
Did you run the car hot?
Old Oct 4, 2008 | 12:03 PM
well i when i went to go buy it.. i took it for a test drive... it was getting hot but it didnt over heat... and then it shut off so let it rest a few then drove it about 10 minutes back to the house... and after that it wouldnt start at all... it had a hole in the heater hose and was sraying all over the place... so i changed the head gasket and timed it again i couldnt get it started... ive never timed a motor before so i was going by the chiltons manual.... and so i took the head off again and there are grooves in the pistons from where the valves have been hitting... and there are gashes in between the two exhaust valves on two cylinders... on one cylender the gash is keeping one valve from seating... i could take pictures of it so you can see.... but i need help... im a lil worried
Old Oct 4, 2008 | 02:57 PM
dsm1990gsx's Avatar
Sounds like you timied it wrong, did you crank the engine over by hand first? Post the pics you have.
rmplstlskn
May 13, 2022 02:49 AM
Rony
Apr 10, 2013 03:41 AM
newoutlanderfan
Nov 26, 2010 06:21 AM
johneast
Oct 31, 2008 02:55 PM
1999GalantES
Jun 11, 2007 05:56 AM
