new air intake and new stalling problem?????
Old May 19, 2006 | 09:00 PM
vdog74's Avatar
Default new air intake and new stalling problem?????
Hey yall whats up? ive had my 94 mitsubishi eclipse since Nov 2005. Its a 4spd, 1.8 liter stock engine. Recently ive installed an INJEN air intake, now ive got issues. Ever since ive installed this damn intake, my car has a stalling issue. There is no check engine light and only happens when i step on the clutch pedal and brake pedal. My mechanic said it didnt happen to him and just raised the idle, that did nothing. i brought it back to him and he reset the computer. That worked for a day and the issue is back. my car had no problems before this at all. I know this is related to the intake, and i need answers....
Old May 19, 2006 | 10:40 PM
Default RE: new air intake and new stalling problem?????
Just take off the negative battery terminal and pump the ABS or something to drain power. Then wait a little bit and connect it again. Then drive it around a little and it should be fine...
Old May 19, 2006 | 11:25 PM
nYOfas's Avatar
could it also that the motor isnt getting air? Or enough air? Cause from experience freinds and I hooked up an intake one time that was installed wrong and it was do the same thing, it just wasnt produceing air
(crazy experience)
Old May 21, 2006 | 10:37 PM
one of the most common problems after an intake is installed is that something goes wrong with the MAF. I suggest checking that out, make sure that the wiring is hooked in right.
Old May 22, 2006 | 12:42 AM
Evil1993Eagle's Avatar
Did you check for any kind of vacuum leaks?
Old May 22, 2006 | 04:51 PM
Santa's Avatar
Between Sebba and Evil 1993Eagle you should have a solution.
Old May 23, 2006 | 01:41 AM
estraw's Avatar
wow! this seems to be a popular topic... cold air intakes stallin out a car. someone should prolly make this a sticky
Old May 23, 2006 | 12:37 PM
its simply because the car has not adapted to it yet...
Old May 23, 2006 | 12:47 PM
ORIGINAL: Sebba
thats not always true.
apw5060
Sep 23, 2011 08:00 PM
naruto454
May 24, 2007 05:22 PM
kaiba408
Feb 14, 2007 06:56 PM
kniel023
Dec 28, 2006 12:51 AM
