oh no!!!
Old Jan 13, 2006 | 01:52 PM
Sanguinius's Avatar
Default RE: oh no!!!
Port and polishing is something only a shop can do. Basically what it is is they take your head and intake and smooth the surfaces out. Anything leftover from maufacturing and any texturing becomes smooth. Basically the difference between a cast metal look/feel and a smooth look and feel. Esentially it removes anything that would impede the airflow and the fuel flow into the cylinder and the exhaust flow out of the cylinder. Thereby giving you more power. Also might think about going with bigger valves since you'll be getting the head job done and a more aggressive cam set. BUT DO YOUR RESEARCH!!! Find out which cams work best with what OTHER gear. Now this you have to think about in 2 ways as well. You can look up gear that works great with your current setup OR if you're planning on doing more mods in the very near future look into what will work well with what you PLAN on getting. If you do this the second way then make sure you're not going to change your mind later down the line. Then your power graphs will change depending on how the different equipment reacts with what you've changed.. Get where I'm going with this?
Old Jan 13, 2006 | 10:43 PM
93eclipsegsx's Avatar
yeah i get what you talking about. but i took the head off today and it doesnt look pretty.
Old Jan 14, 2006 | 12:03 AM
little timing slip huh? time for a nice build up
Old Jan 14, 2006 | 12:10 AM
maverick359's Avatar
we have crappy luck 93eclipsegsx
Old Jan 14, 2006 | 12:17 AM
ORIGINAL: maverick359
you drive a DSM lol thats what happens.... im kidding but when you start to modd be ready for it
Old Jan 14, 2006 | 01:04 AM
is buying a 2.3L stroker kit worth it or just buy new pistons because the cylinder wall has no damage done to it.
Old Jan 14, 2006 | 01:09 AM
ORIGINAL: 93eclipsegsx
that is your call. a stroker make for better spool times and TQ if your going with a big turob then why not
Old Jan 14, 2006 | 01:27 AM
do they cost a lot and is it worth the money, it seems to me i have to buy new pistons so why not right??
Old Jan 14, 2006 | 09:47 AM
well I know for the EVO they range from $2300-$6000 depends on the brand pistons and rods. remember these kits come with rods and a crank so they are more expensive than buying just pistons.
Old Jan 14, 2006 | 12:07 PM
will a 6-bolt motor fit my car? and if so, should i go and buy a block, buy the stroker kit and get a ported head? or is there a better route to go?
