pistons
Old Nov 14, 2006 | 07:08 AM
racerx55's Avatar
Default pistons
so i have a 7 bolt engine, pistons are listed for 93-94, or 95-99, whats the easiest way to tell if its a 93-4 or 95+ bottom end?
Old Nov 14, 2006 | 09:43 AM
RCJr9186's Avatar
Default RE: pistons
all 95-99 are 7 bolt.
Old Nov 14, 2006 | 09:44 AM
Default RE: pistons
well he was asking how to tell the difference between a 1993-1994 engine to a 1995+ engine
Old Nov 14, 2006 | 09:45 AM
silvercoupe97's Avatar
Default RE: pistons
..but he asked about the bottom end.
Old Nov 14, 2006 | 09:50 AM
Default RE: pistons
i interpeted his question as he knows its a 7 bolt, but wants to know if its a 1g or a 2g 7 bolt. I think is that the 1g's had a smaller compression ratio than the 2g version. But other than that, i dont know any way of knowing which year it is
Old Nov 14, 2006 | 09:58 AM
RCJr9186's Avatar
Default RE: pistons
let me help everybody out - racerx55, what exactly is your question? are you looking to know which pistons to buy? or are you asking which bottom end is which and how can you tell the difference? because a 7 bolt is a 7 bolt, don't matter if it's from a 93 or a 99
Old Nov 14, 2006 | 10:03 AM
racerx55's Avatar
Default RE: pistons
i want to know what pistons to buy, its a 7 bolt, i was assuming its a 93-94 because of the 1g head, but by the looks of this engine its a n/a motor with a turbo head,paperwork on the car shows a 95 engine being put in, so it could be a 1g head on a 2g bottom correct?
i dont trust a paper to tell me what it is so, what i want to know, is by looking at the bottom end how do you tell weather its a 1g or 2g (7 bolt of course)
thanks for anyones help
Old Nov 14, 2006 | 10:09 AM
RCJr9186's Avatar
Default RE: pistons
as far as i know. a 7 bolt is a 7 bolt. doesn't matter if it comes off a 93 or 99. now i never thought about this until now but... i'm not sure if there is any issues with taking a 7 bolt from a NA 1g eclipse and putting a 2g head onto it...
Old Nov 14, 2006 | 10:10 AM
Default RE: pistons
i think the block itself it pretty much identical. I dont know of any #'s or anything that would clue you in, all i know is that the compression ratio on a 95+ should be like 8.5:1 where the 1g's where 7.8:1.
Old Nov 14, 2006 | 05:05 PM
racerx55's Avatar
Default RE: pistons
ORIGINAL: RCJr9186
well when pricing pistons for a 7 bolt, its lists 1g 93-94, then 2g 95-99, theyre priced different so somethings gotta be different about them, maybe the difference in CR is all its is..
