what up peeps?
Old Jul 28, 2009 | 06:43 PM
jason clipse's Avatar
Default what up peeps?
i haven't been on in a while. i used to have a 95 420a eclipse. now i have a 90 talon tsi i got it for pretty cheap and runs really well. on about 20lbs of boost right now. gonna be on more often now that i have a dsm again. in the time i've been gone, i've joined the army and am about to deploy to iraq. i shall be on here a lot on my downtime
Old Jul 28, 2009 | 07:22 PM
welcome back. 20lbs of boost...i hope thats an upgraded turbo because the stock 14b wont last long on that
Old Jul 28, 2009 | 07:29 PM
dsm1990gsx's Avatar
Welcome and what TE said what turbo are you running? Mods list?
Old Jul 28, 2009 | 07:48 PM
16g, 550cc injectors, walboro 190 fp, apexi afc neo, data logger, aem tru boost boost guage/ boost controller, aem uego wideband, front mount, nrg fuel pressure regulator, greddy type rz bov, tien springs on new gabriel ultra socks to be installed this weekend
Old Jul 28, 2009 | 07:58 PM
dsm1990gsx's Avatar
J/w what injector dutey cycle are you seeing at 20 psi? I was maxing out my 560's at 18 psi. Are you running the stock 1g maf?
Old Jul 29, 2009 | 12:05 AM
no running a vr4 maf and i cant remember. i will let u know tommrow sometime, i will check. it took me running +32 on the neo to hit fuel cut and thats cause i turned it up to see how much it took. the car only runs on +19 or 20 max tuned. so nowhere near it but i will give u an exact number probably tommrow. and i forgot to add that i got drilled and slotted rotors and carbon metalic pads. im sure i forgot other things too
Old Jul 29, 2009 | 06:48 AM
nice mods list. Too bad its only a tsi and not an awd. but i guess you can only get whats available.
Any plans on going to the track? Id love to know what time that can pull
Old Jul 29, 2009 | 04:08 PM
it is awd and the kid i bought it from ran a 13.4 on 16lbs of boost with a sidemount, that was 10 less hp than i ran on a sidemount, tune and 18lbs of boost. i have yet to dyno with the frontmount, but after i go get a little tweaking i plan on going to the track. i too want to see what this thing can run. it pulls hard as hell. hopefully i can get more pics today too.
plus it needs the suspension im going to put on it this weekend. its way soft and squats (too hard in my opinion) hard even on the highway. i figure taking some of that "slack" out will help the power get down.
Old Jul 29, 2009 | 05:30 PM
dsm1990gsx's Avatar
You should be high 12's easy, you pretty much have the same setup as me. but w/ a little more boost.
Old Jul 29, 2009 | 06:57 PM
yea i got to learn how to launch an awd car its my first one. thats probably what is going to kill me the most on my 1/4 mile time
also: i will log some runs later when its not hot as ***** outside. got to 103 today
