WTF
Old Mar 3, 2007 | 11:55 AM
racerx55's Avatar
Default WTF
WHY in the F*** does this F******* boost controller keep turning itself down[:@]
Old Mar 3, 2007 | 01:21 PM
Default RE: WTF
What kinda boost controller?
Old Mar 3, 2007 | 01:41 PM
TheAdvocate's Avatar
Default RE: WTF
manual? electronic?
Old Mar 3, 2007 | 01:49 PM
racerx55's Avatar
Default RE: WTF
TurboXS manual, 0-30 psi.... ****in junk
Old Mar 3, 2007 | 01:57 PM
50ul }{4ck3r's Avatar
Default RE: WTF
i have a TurboXS Conversion Boost Controller and i don't have a problem like that ...may be its a bad unit...my 2 cents
Old Mar 3, 2007 | 02:00 PM
Default RE: WTF
Does everything seem solid when you adjust it? How easy does it turn when you adjust it?
Old Mar 3, 2007 | 05:56 PM
racerx55's Avatar
Default RE: WTF
Turns too easy IMO, i took it back once and got another and this one does it too.
piece of ****. Mostly when i drive on the highway,constant higher RPM vibration i guess. Im gonna try leaving it hang on by the hoses instead of having it zip tied to the recirc hose.
Old Mar 3, 2007 | 06:24 PM
soundcolor's Avatar
Default RE: WTF
if its electronic, you may have the one of the settings set wrong... check your manual, or tell us what you've got so we can better help.
Old Mar 3, 2007 | 08:38 PM
racerx55's Avatar
Default RE: WTF
ORIGINAL: racerx55
Old Mar 3, 2007 | 08:58 PM
soundcolor's Avatar
Default RE: WTF
hmmm. I think Im stumped here. Unless either you are hitting the ****, or one of your wires is loose, or improperly connceted
