1995 eclipse GS-T 4G63T ENGINE SWAP!! Need Some Help!!!
Old Apr 30, 2005 | 05:34 AM
matt02708's Avatar
Default 1995 eclipse GS-T 4G63T ENGINE SWAP!! Need Some Help!!!
How much would i wind up spending altogether for this swap?? What do you think i'll be putting out??
Old Apr 30, 2005 | 03:35 PM
DSMTalonAWD51's Avatar
Default RE: 1995 eclipse GS-T 4G63T ENGINE SWAP!! Need Some Help!!!
4-5k
Old May 2, 2005 | 12:45 AM
nate5023's Avatar
You should sell you car and buy a gs-t or gsx because, these aren't like hondas its a lot harder to make engine swaps.
Old May 2, 2005 | 01:19 AM
Sanguinius's Avatar
Yep definately NOT like hondas
Old May 2, 2005 | 04:09 AM
matt02708's Avatar
The car i'm buying is a 1995 GS-T.
Old May 2, 2005 | 12:02 PM
get435's Avatar
ok if you have a gs-t you got a 4g63 turboed motor. now to pull the motor and overhaul it would cost between 1-2k depending on what internals you will use. This will make the motor like new and if you bore the motor a little more power. the only downfall is you have to brak the motor in so there woul be no racing for 1000-1500 miles and you would be advised to change the oil after the first 500 and than once more at 1000 miles. after that it would run like a champ. if you find a good macinest that dose that stuff for a living he will tell ya what would be best for the overhaul as far as internals and cost.
gs03
Oct 10, 2021 03:48 PM
rstoevo
Jan 20, 2013 10:47 AM
NYKID
Nov 8, 2008 04:26 PM
BigSteve0034
May 20, 2005 02:42 PM
xblade
Nov 20, 2004 11:54 AM
