1G Swap for mY 98 GsT
Old Apr 19, 2006 | 03:47 AM
B.e.R.a.T's Avatar
Default 1G Swap for mY 98 GsT
I know a lot of people ask the same question maybe million times but if i wanna swap 1G bottom and 6 bolt one should I get i Turbo end or regular gs will be fine too. also what else would I need after swapping it and will it effect my modifications on my car. if I swap the bottom and the turbo from the 1G will it be safer. please give me some Ideas thanks.
Old Apr 19, 2006 | 11:59 AM
Default RE: 1G Swap for mY 98 GsT
I would get the 1g 4g63t. It has better internals and rods. BTW where are you located. I currently have one that i am selling
Old Apr 19, 2006 | 12:01 PM
your stock turbo is junk so swap it with at least a 1G 14b if not a 16G. the 1G bottom end is a 6 bolt and no it shouldnt mess up your current mods. yes the block will be able to handle more power, it doesnt crank walk
Old Apr 19, 2006 | 03:22 PM
B.e.R.a.T's Avatar
I am in Columbus, OH. R u selling a complete 1G engine let me know. I might be interested.
EMonz57 will u please give be more information and If u have ideas how much it will cost me to put all that in my car. I will buy a used turbo from a junkyard what should i check before i buy one. 16g is the one in the evo's isn't it and if i buy one do i need to change my internals or what do i need to change thanks a lot.
Old Apr 19, 2006 | 05:51 PM
TheEngineer has a 6bolt GSX block from a 1992 and head that is ported with a 3angle valve job (as well as a JDM VR4 tranny).
The current EVOS use the 16G but you cant use that one, you need the EVO III style one or an aftermarket companies 16G like bushur racing. I cant tell you the cost of any of it since it varies on mechanics and if you can work on it yourself. It is a little project I think DSMtalonAWD on this forum has the swap in his TSi AWD
Old Apr 21, 2006 | 01:48 AM
B.e.R.a.T's Avatar
what exactly the vr4 tranny will do to the car is it a big increase.
Old Apr 21, 2006 | 09:53 AM
the vr4 tranny is just alot stronger becuase that was a main problem with the 1g's from what i understand is that they break easily.
Old Apr 21, 2006 | 10:42 AM
slow420a's Avatar
you have to re wire the cas
http://www.roadraceengineering.com/1gcasin2g.htm
rstoevo
Jan 20, 2013 10:47 AM
95 gst
Feb 11, 2007 06:23 PM
95HGeclipse
Jan 23, 2006 09:05 PM
magno_313
Jan 8, 2005 11:57 PM
mike96eclipseRS
Dec 19, 2004 05:07 AM
