2.4 liter swap
Old Feb 25, 2004 | 08:35 PM
1girlygirl's Avatar
Default 2.4 liter swap
Has anyone here done it, heard about it. I am in the process of doing it so just wondering.</P>
Any opinions or knowledge would be good.</P>
Old Feb 26, 2004 | 02:06 PM
91eclipse's Avatar
i have no ideaR how hard it would be........i have heard of it but i havent did it....im interested in doing it too.......well, i have a plan 4mi eclipse....i wanna find a wrecked mitsubishi300gt and rob it for the engine...tranny....rearend and frontend ....my eclipse would be the meanest around.....hmm....
Old Feb 27, 2004 | 11:32 AM
SpyderGS's Avatar
Well, I did something like that swap. I have a Spyder GS(can you tell?) that came with a 4g64 2.4l engine stock. I already did a head swap from the 1g 4g63's because my car came with a SOHC head. So now it's basically the same as a stroked 4g63. Minus the turbo parts because i'm poor and can't afford to buy all the conversion parts yet. Anyways, uhhh...you have an eclipse gs, right? If a\it's a spyder, then your in luck and can do what i did. If it's not a spyder, then you'll have to take another route. The non-turbo versions of the hardtop eclipse's came with a chrylser engine that is in no way related to eclipse turbo except for the fact that it's in an eclipse body. None of the engine parts, sensor, gauges, transmission parts or even axles are the same or compatible. I use to have a 97 non-turbo talon which was the same as your eclipse and have thought about swapping to a turboengine. Turns out it's way more difficult and expensive than you can imagine. It's not like swapping a honda engine or small block chevy engine, those are both easy(relatively). It would be like swapping a chevy engine into a honda actually. Not feasible, and definitely not worth it. </P>
But you are in luck. Chrysler did make a 2.4 variant of your engine(420a is the engine code, look under the hood and a sticker should have engine code on there) As a matter of fact, the dodge neon srt4 is using it right now. That engine is also turbocharged and is making around 250whp using a mitsu turbo. As to whether the engine will drop into the eclipse chasis, i don't know. But Dodge did make a few cars and vans with 2.4l 420A. The most prevalant and easist to find, not to mention cheapest, is in the dodge caravan. I'ts probably best to find a wrecked caravan made in the 90's since the n/t eclipse's shared the same block as them. You will have to use atiming belt from a 2.4l dohc caravan though, so best to do the block swap when you're ready to do a T-belt job. As for the turbo, honostly, in my opinion, you don't need anywhere close to a t3/t4. For your engine combo, a t3/t4 would spool up rather quickly.It's like putting a 20g on an mk4 supra, It's not undersized but it'syou're going to realize the full potential of the engine itself. T3/t4 are good for undersized Honda's that can't make any torque. For you're massive 2.4l you'll need at *minimum*a 14b mitsu turbo. The recommended turbo is a big 16g, like the one used in the srt4. If you want a hi-po combo, use a 20g. But get a built bottom end first, no sense in spending close to $5000 just to have a piston shatter and destroy you're $2000 turbo, manifold, and exhaust system. good luck</P>
Old May 3, 2010 | 01:44 AM
Gh0sT's Avatar
Default 2.4l engine
i was wondering what i could do to get more out of my engine. i have a 97' spyder gs 5spd in really good shape at 110k and the engine is clean no leaks knocks nothin. but its a dog! i have a weapon r intake on it with ram air, and a venom 400 series chip. but its not enough, if that ****s workin like they say its supposed to i should be around 180whp. pfft, any ideas?
Attached Thumbnails 2.4 liter swap-24902_371511623839_509978839_3585791_4740403_s.jpg
Old May 3, 2010 | 07:41 AM
Old May 6, 2010 | 12:49 AM
Gh0sT's Avatar
thank you soooooooooooooo much
Old Jun 4, 2010 | 09:26 PM
oh_what_up's Avatar
1girlygirl....
Depends what you engine is stock... I had the 4g63-T and I swapped the 4g64 with no issues... There are some minor details that need to be addressed, but if you don't have a turbo 2g than I'm sure if I can help you... if you do... hit me up and I'll go into specifics and I'll help you out the best way I can... good luck
oscaman
1st Generation
Dec 29, 2010 09:46 PM
importpreformance
May 3, 2009 08:06 PM
760_3000GT
Aug 10, 2006 05:08 AM
Tom Piantanida
Apr 21, 2006 11:41 PM
Hephaestus
Nov 6, 2005 11:31 PM
