4g64 low oil pressure at idle
hi , rebuilt a 4g64 , new conrod and main bearings , new oil pump, new oil pressure switch,. and balance shaft removal kit installed.
yet at idle the oil pressure light comes on, and when it does , there is NO noises at all coming from the engine, but as soon as you bring the revs above idle the oil press light goes out.
is there a way to increase the oil pressure ?i was thinking with the spring/plunger setup where the oil filter screws on ?
thanks,
mark k
thanks,
mark k
thanks,
mark k
thanks,
mark k
I have the same problem with a 2006 Galant 2.4L. Changed the oil Switch. The Road Bearings, the Main bearings, the battery and still the oil light comes out at idling. called a mechanic he tighten some vacuum hoses and say tha I can drive the car like that, because it dosent make any strange noises but Id like to get more answers do guys have clue of whats going on?
amandarenee
May 19, 2022 06:04 AM
