60k eclipse service
Old Mar 12, 2008 | 05:39 PM
johnyredd99's Avatar
Default 60k eclipse service
just hit 61000 miles on a 98 GSX...believe it!! Iwas trying to put off the service like a dumb *ss noticed the timing belt was about to go so into the shop it goes...
what is getting done...
both belts
belt tensioner
water pump
front and rear differential fluid... what do you recomend??
new brake fluid
clutch fluid... again what is recomended???
oil and coolant were just done..
what else does everyone recomend???
thanks
Old Mar 12, 2008 | 06:02 PM
Default RE: 60k eclipse service
BG Syncroshift according to all the EVO folks. Personally Iwould stick with the Mitsu fluid.
Any synthetic DOT 3-4 fluid. Not mineral.
Actually you covered just about everything. Maybe a spark plug and wire change. That would be NGK Classic plugs, and stock Mitsubishi wires.
Oh, and I want to see some pics of this clean *** GSX : )
Old Mar 14, 2008 | 11:53 PM
nemzy's Avatar
maybe inspect your belts and hoses for cracks leaks or being warped and brake hose. since your going threw all that.
Old Mar 15, 2008 | 06:59 AM
darknigh7th's Avatar
though from what i can see it has a bra on it, take it off
Old Mar 15, 2008 | 12:06 PM
Yeah I have heard of those fusing to the paint under heat... and removing paint when you take them off.
Old Mar 15, 2008 | 12:10 PM
TheAdvocate's Avatar
Ya, they are terrible on the paint job.. My brother had one when I was younger and the paint peeled right off under it.. My wife had one on her maxima and you could see the paint starting to go to crap when we traded it in..
Old Mar 15, 2008 | 12:12 PM
If you want to protect the paint, put 3M Clear Vinyl over it. That stuff is bad ***
Old Mar 15, 2008 | 12:34 PM
i just never have liked car bras. thats why i said to take it off, not for paint lol.
Old Mar 15, 2008 | 12:37 PM
dsm1990gsx's Avatar
You should also replace the fuel and air filters.
Old Mar 15, 2008 | 12:45 PM
yeah, do a full tune up, and it should run smooth..
rwcos
Mar 29, 2013 11:42 AM
mda185
Apr 3, 2011 08:28 AM
Jalapeno
May 14, 2010 09:47 PM
Xenoid
Aug 19, 2008 09:21 AM
valjohnd
Mar 25, 2005 09:33 PM
