Anyone had 60K mile valve adjustment service done?
Old Mar 17, 2011 | 02:06 PM
mda185's Avatar
Default Anyone had 60K mile valve adjustment service done?
My 07 Outlander LS has 65K miles on it and is due for valve adjustment. I am wondering if anyone on the forum has had this service done and what they paid for it if performed by a dealer or independent shop. I am not sure if this is a reasonable DIY job. Any info will be appreciated.
Old Mar 17, 2011 | 04:35 PM
ccernst's Avatar
After looking at the service manual, this does not look to be the easiest of checks....we skipped it.
Old Mar 22, 2011 | 12:04 PM
Vadimus's Avatar
What do you mean? It seems not very tricky.
1. Warm up engine, remove coils, cover.
2. Check the clearance, adjust as needed. Repeat 12 times.
3. Put back cover and coils.
part of Service Manual
No special tools required. The only problem I see - there are 12 of exhaust valves, so you should be quick to do it before engine cools down - clearance of .2 mm (.008") is for 80-95C (176-203F) warmed engine.
Old Mar 22, 2011 | 03:04 PM
ccernst's Avatar
I have a real dislike for removing rocker/valve covers. Last two vehicles I've done (Ranger 3.0L and Grand Prix 3.8L) have been real pains. It isn't like the older V8s where you just pop the covers off. The ranger had to take the upper intake manifold, coil pack, throttle body off to get access to driver's cover. The grand prix, I remember the coil pack came off, one fuel rail. There were lots of other little tidbits to disconnect...but I forget the whole list.
Looking at 11B-14 shows that the intake manifold plenum (I'd call it the upper intake manifold...) would also need to come off. So then you'd need to make sure that you pick up a set of valve cover gaskets and "intake plenum" gaskets...just for an inspection. Maybe at 100k I'll check it. Engine sounds real good so far.
Old Mar 23, 2011 | 01:47 PM
Vadimus's Avatar
You're right, after having a quick look at the rear bank, blocked by intake manifold, now I fully agree with you
Old Apr 1, 2011 | 07:04 PM
milliesdad's Avatar
Adjusting the valve lash is a lot less expensive than replacing a cam shaft. I picked up a '73 Capri that the owner didn.'t know that the valve lash had to be adjusted. Little Ford 2 ltr. for $25.00. Replaced cam and followers, drove the little devil for 2 years until rear-ended.
Made a lot of money off an owner that didn't service his car.
Old Apr 2, 2011 | 12:00 PM
mda185's Avatar
Damage to the engine is what I am worried about. Loose valve clearances are merely annoying. Too tight, and I am afraid of wear to the cam and followers. My engine still runs well but I have noticed that the slight valve tick it had around 44K miles is now gone. Makes me wonder if clearances have gotten smaller. Looks like I will have to set aside a Saturday to do this.
Old Apr 3, 2011 | 08:28 AM
milliesdad's Avatar
If you are wiorried about engine damage, do the valve adjusment. If you no longer hear the valves ticling, they are running tight.
ckmecha
Mar 10, 2014 05:31 PM
Jalapeno
May 14, 2010 09:47 PM
rcpax
Sep 18, 2008 04:15 PM
Xenoid
Aug 19, 2008 09:21 AM
johnyredd99
Mar 15, 2008 12:45 PM
