96 eclipse gs spun rod bearing.
Old Feb 5, 2010 | 11:54 PM
Sicken's Avatar
Default 96 eclipse gs spun rod bearing.
I am considering buying a 1996 eclipse, but it has a knock in the engine. I figure its a spun bearing, but i was wondering if this is a common problem for this year? and would i have to remove the engine to change the bearings or could i go up from the oil pan while the engine is still in? Also, does anyone know of any other problems i might run into with this car?
Thanks!
Old Feb 8, 2010 | 09:58 AM
your going to want to remove the engine because you dont know what other damage it may have caused and youll need to hone out the cylinders. Also youll want to do a headgasket change while your doing everything else anyway. Id say just do a complete rebuild and then youll have no worries
Dustin0330
May 3, 2015 01:10 PM
mcguffp
Jul 5, 2007 06:00 PM
DBIGGS
Feb 19, 2007 01:52 PM
clips69
Dec 24, 2006 03:08 PM
staszek10
Nov 13, 2005 02:08 PM
