98 eclipse problem
Old Dec 26, 2007 | 10:54 PM
kingkong's Avatar
Default 98 eclipse problem
hi
people i have a 98 eclipse gs with a 420a stock i found out that i couldnt get it over 100mph it stopped and rpms were steady gas pedal was all the way down to the floor i think the governor or pilot stops it from going over 100. my question is if i put tat piggy back system on the ecm is it going to stop governor from stopping my car at 100mph? if not thatn what should i do and where should i get the parts or whatever i need
any help will be appreciated
thank you
Old Dec 26, 2007 | 11:26 PM
bestwiseguy's Avatar
Default RE: 98 eclipse problem
the rs and gs doesnt have a governor, those cars are just underpowered.
Old Dec 26, 2007 | 11:33 PM
_Adrian_'s Avatar
yes there is a governor on the vechicle...
and yes going to an aftermarket engine management unit will alow you to bypass the governor.
the reason behind the governor was the H-Rated tires that were used.
unless you have a good set of Z rated rubbers i wouldnt even bother unless you wanna pop a tire at 100Mph i would say it would suck.
anyways ...your canget i a "speed cut defender" at HKS or Greddy. if my memery server right they both offer it.
do a search on the net and you should find some info on it.
good luck and dont try anything stupid on cheap rubbers.
Old Dec 26, 2007 | 11:38 PM
Wrong, that was the GST, and it was limited to 135.
Old Dec 26, 2007 | 11:40 PM
_Adrian_'s Avatar
most 96 and up ODB2 compliant vechicles have a 100MPH governor, specially california equiped vechicles !!!!
Old Dec 27, 2007 | 03:24 AM
Dusty Eclipse's Avatar
ORIGINAL: _Adrian_
Youre referring to the cut off in the 95-99 GST ECU. The 420a (RS/GS) Didnt have it.
Old Dec 27, 2007 | 07:14 AM
my solution.....stop trying to drive over 100mph. There is no reason you need to even try it unless your at a track...in which case by the end of the 1/4 mile you still wont have reached 100mph anyway
Old Dec 27, 2007 | 10:28 PM
JOLLYAFROMEN's Avatar
yea i have a stock GS, and i was out last week on the Interstate, made sure no one was around, and made sure the road was smooth, i got up to 110, b4 i started getting scared , im not gonna lie, it is pretty scary when the car starts shakin.
Old Dec 27, 2007 | 10:30 PM
TheAdvocate's Avatar
My first eclipse I had was a GS and I had it in the upper 120's...
(Not recommending anything)
ang099
Jun 28, 2004 12:15 AM
ang099
Jun 20, 2004 06:53 AM
Libra0281
Jun 1, 2004 12:24 AM
tjrcs
Oct 7, 2003 04:28 AM
