for all the gst's
RE: for all the gst's
oh ya i would run my self over i am having a body shop replace my front blitz bumper for a stock 2 g bumper and iwill have them look and see if they can find it if i cant. they are very reputable around north idaho so i trust them 100% they have alot of work cutting out my fiberglassed in blitz bumper to put a stock one on. so it will look good i hope with my green chameleon paint. so we will see thanks guys ill try and clean it and find it myself thanks for the tips and ideas anything else that might leak?
with a 2g, its a never ending battle to stop all the leaks from gaskets/seals wearing out because the metal that the gasket is applied to isn't the same way it use to be when new. On my car, it took 2 months to find and stop all the leaks but 2 months later I had another leak but coming from a speed bump. Oil pan.
well it stopped now and its weird i have been checking the oil like every other day and it isnt moving now but i need an oil change maybe they can take a look since they be under the car any way. is synthetic worth it??? i want to change over to synthetic any downsides besides cost? is any benefits?
Dose it have the stock turbo? If so pull one of the IC pipes off and see if there is any oil in it if it dose check your compressor wheel and if it wobbles at all. If so your barrings in the turbo are going out and leaking past the seals i have seen this a lot with stock turbo with a lot of miles on them.
Edit:
If u had a oil leak or it is a small leak now i would not go syn it will make it worse.
Edit:
i have a big 16g should i still check the ic piping? it seems to have stopped so i dont know. i really need to get atuning devicetho so i stop running so rich or get a fmic and new upper ic pipingso i can put my new recirculating bov on.
ultrarevvin1
01-14-2014 09:48 AM
ultrarevvin1
01-11-2014 11:58 PM
ultrarevvin1
01-11-2014 07:13 PM
ultrarevvin1
01-11-2014 06:58 PM
