for all the gst's
Old Aug 12, 2007 | 06:02 PM
Dusty Eclipse's Avatar
Default RE: for all the gst's
Im gonna say oil pan, too. Those things get the **** kicked out of em. Speed humps and whatnot.
Old Aug 12, 2007 | 08:03 PM
atown420's Avatar
oh ya i would run my self over i am having a body shop replace my front blitz bumper for a stock 2 g bumper and iwill have them look and see if they can find it if i cant. they are very reputable around north idaho so i trust them 100% they have alot of work cutting out my fiberglassed in blitz bumper to put a stock one on. so it will look good i hope with my green chameleon paint. so we will see thanks guys ill try and clean it and find it myself thanks for the tips and ideas anything else that might leak?
Old Sep 20, 2007 | 08:23 PM
Stryker's Avatar
with a 2g, its a never ending battle to stop all the leaks from gaskets/seals wearing out because the metal that the gasket is applied to isn't the same way it use to be when new. On my car, it took 2 months to find and stop all the leaks but 2 months later I had another leak but coming from a speed bump. Oil pan.
Old Sep 20, 2007 | 09:32 PM
TheAdvocate's Avatar
Ya, that return line is prolly the most common leak on these cars.. But that does seem like a lot to be adding every 2 weeks if its just coming from there..
Old Sep 21, 2007 | 11:07 AM
atown420's Avatar
well it stopped now and its weird i have been checking the oil like every other day and it isnt moving now but i need an oil change maybe they can take a look since they be under the car any way. is synthetic worth it??? i want to change over to synthetic any downsides besides cost? is any benefits?
Old Sep 22, 2007 | 01:51 AM
Gstfat's Avatar
synthetic runs good,but remember once u go synthetic u can pretty much never go back(use royal purple)
Old Sep 25, 2007 | 04:08 PM
get435's Avatar
Dose it have the stock turbo? If so pull one of the IC pipes off and see if there is any oil in it if it dose check your compressor wheel and if it wobbles at all. If so your barrings in the turbo are going out and leaking past the seals i have seen this a lot with stock turbo with a lot of miles on them.
Edit:
If u had a oil leak or it is a small leak now i would not go syn it will make it worse.
Old Sep 27, 2007 | 12:44 PM
atown420's Avatar
i have a big 16g should i still check the ic piping? it seems to have stopped so i dont know. i really need to get atuning devicetho so i stop running so rich or get a fmic and new upper ic pipingso i can put my new recirculating bov on.
Old Sep 27, 2007 | 03:01 PM
get435's Avatar
Wouldnt hurt to check and see if there is oil in there.
ultrarevvin1
Jan 14, 2014 09:48 AM
ultrarevvin1
Jan 11, 2014 11:58 PM
ultrarevvin1
Jan 11, 2014 07:13 PM
ultrarevvin1
Jan 11, 2014 06:58 PM
BLAZE GS
Feb 5, 2008 09:35 AM
