Almost done with swap. Need a little help
Is the hole in the block supposed to be in the same spot as the 7 bolt for the knock sensor? Thats the only thing i dont have plugged in... I cant find the hole for it? Am i gonna get a CEL if i dont plug it in?........or will the motor just explode without it?
Also im having slight clutch problems. theres almost no feel until about 3/4 of the way down. It kinda just feels like its either on or off. Ive bled it very well....i think the slave cylinder might just be bad.
Any thoughts?
Any thoughts?
ORIGINAL: Jeffisdecentttttt
I went to the magnus website and the diagrams they have for the cam sensor, dont have the same color wire as the one im using. I made this crappy picture to show you how its hooked up. Is this right?
^^ http://www.roadraceengineering.com/1gcasin2g95-96M2.htm
Did you by chance invert the plugs or do you have DSMLink to invert the signal for you? If neither, I would recommend inverting the plugs like it says in the link.
Any thoughts?
Any thoughts?
[IMG]local://upfiles/10268/FD729B789B5646D7A4EF4A5A6E1AE5DF.jpg[/IMG]
or
[IMG]local://upfiles/10268/DB923CD89841415DA1529739C8517B29.jpg[/IMG]
As for the clutch engagement, it may be a bad slave. Check for leaks by the piston by pulling back the rubber boot. Look for leaks on and around the master.
If it's all good, bleed it. Another thing to do is move the engagement point on the pedal itself. Anytime any clutch work is done, you should have to adjust it every time....unless the point is dead on that is
thats the same thing that is on magnus
Did you swap the plug wires?
You had the two black wires inverted also, correct? As in they were just backwards and that was causing you to have issues?
So with the CAS inversion and plug swap, the car shouldn't give random missfire. I thought i had this all understood. Need some clarification. Or was it just for the 95-96 ECU and the 97 ECU and up didn't require the plug swap and CAS inversion.
93-94 hall effect CAS seems to be the most wanted when it comes to swaps in 2Gs because they are more accurate and they don't have misfiring issues.
I have a 95 EEPROM ECU with my mutt motor and I had misfire issues before DSMLink. I think I read somewhere that the non-EEPROM ECU motor swaps from 2GBs were fine without inverting the signal or wires. Let me do some more research on that and I'll get back to you bud.
