Another Grumble in exhaust...
Old Dec 5, 2006 | 08:50 AM
  #21
Default RE: Another Grumble in exhaust...
ORIGINAL: agallardo
Well i am still wondering if you guys think i should take the head to the machine shop?
your better off having it machine before you put the head back on
  #22
ORIGINAL: agallardo
So I am guessing i do have to take my head to a machine shop? Or can I just replace the head gasket? By the way, there wasnt oil all over my engine bay... but there was a trail of smoke.
I already talked to Sebba about that post on aim... lol!
you did say coollant was all over the engine bay.
Old Dec 5, 2006 | 01:31 PM
  #23
agallardo's Avatar
Yeah man. There was coolant all over the engine bay, but not oil.
Old Dec 5, 2006 | 01:47 PM
  #24
EMonz why is he better off taking it to a machine shop?
Old Dec 5, 2006 | 02:05 PM
  #25
98eclpsrider's Avatar
i have a grumble noise when i semi floor it, but i accelerate like hell, but its' my cold air sucking some air, but i would agree in taking it to get machined before you put it back on.
my friend had a grumble noise from his cold air, but when it stopped he threw a rod on his car.
Old Dec 5, 2006 | 03:18 PM
  #26
ORIGINAL: Sebba
usually when you pull off a head you get it machined and resurfaced. It is not that expensive. And if you blow a headgasket you never know how well off that surface is going to be now
Old Dec 5, 2006 | 03:48 PM
  #27
true... al you really need to do is clean up the surface and bring out the metal... you can do that yourself.
Old Dec 5, 2006 | 04:38 PM
  #28
agallardo's Avatar
Is there a kit to repair the head of my car?
Old Dec 5, 2006 | 04:47 PM
  #29
the head doent need repairing. All you have to do is prepare the surface of it. So just get the metal showing with a polishing kit or maybe something a little rougher. Just make sure the surface is fresh.
Old Dec 5, 2006 | 08:55 PM
  #30
Sanguinius's Avatar
All right I'm going to make it simple for the understanding here.
Block:
Head:
Now try to put the 2 together and this is what you get:
See how the head isn't touching the block at the bottom agian? (Turn it sideways to look at that drawring) Now yours won't be THAT bad. I exagerated for sake of demonstration. That means you'll have a bad seating surface and a weak point for the head gasket to blow again. So take it in to a machine shop and get the head checked and surfaced ONLY if necessary. ALSO REPLACE THE HEAD BOLTS. They are a Torque To Yield bolt. That means when you torque it down it stretches the threads and gives it a 1 time use.
