BAD antifreeze leak!!
Old Apr 5, 2005 | 10:33 PM
97redEclipse0010's Avatar
Default BAD antifreeze leak!!
Okay the other day i pulled into my driveway and some antifreeze dripped out and then it just stopped. It smoked and smelled like antifreeze usually does but then it just ended. So I took it to school today and when I parked nothing happened. I went to a friends house and all of a sudden it started puking like you wouldnt believe. I limped home letting it cool down every few hundred feet it seemed. I have a new radiator and new headers in the mail and they should be here tomorrow. While im getting that fixed im just wondering if anyone knows what else should be looked at. It leaking completely out of the pasenger side and I know very little about cars. Please HELP!!
Old Apr 5, 2005 | 11:57 PM
Sanguinius's Avatar
Default RE: BAD antifreeze leak!!
First check all hoses for splits and cracks then you'll want to look at your freeze plugs those will be the easy things to check. The next on the list is check for coolant coming from the water pump. Those are the only places it could possibly be leaking other than the radiator which you said is already being changed.
Old Apr 6, 2005 | 09:50 AM
get435's Avatar
Check where the top hose meets the head. alot of the time the gasket right there where the thermostat is will leak or just go out. if it dose it while sitting there than try putting som water in it to see if it is a crack in the radiator itself.
Old Apr 7, 2005 | 09:32 PM
vertstanggt's Avatar
And on mine at least the upper hose is on the right side....
Old Apr 7, 2005 | 09:43 PM
well it had over heated pretty bad so i was worried that i had killed it cuase no light came on and i just noticed that my temp gauge was way up. I got a new exhaust manifold and raditor and had the machanic to check all the hoses and connections. He said it hadn't fried anything and everything was secure so I guess im okay now.
Old Apr 8, 2005 | 01:38 AM
Sanguinius's Avatar
Did it stop overheating? It could also be that the radiator needs bled. (Or the cooling system I should say needs bled).
hairbear65
Feb 1, 2009 09:35 AM
poca1313
Feb 18, 2008 10:48 AM
Kayse83
Nov 23, 2007 06:33 PM
Kayse83
Sep 13, 2007 05:34 PM
agallardo
Oct 31, 2006 03:54 PM
